swgj86
my caudabe sheath with action button has just shipped when I haven’t even receive the one with the cut out button lol
mine too! Gonna take about 2 weeks to arrive for the action button cover version.
我要买GTR
Ugreen advantage is price only.
else go for Belkin / baseus for peace of mind.
Baseus is very much cheaper than ugreen tho. 🤣
I stopped using baseus because often the lightning connectors (1 side can charge, 1 side not working) after less than a year. But they are not MFI. No comments on usb-c to usb-c cable tho.
Belkin nv use before so no comments haha 🤣
RadEoNic
I bought my cheap USB-C cables from 2 sources.
1. Charging
Baseus cables are rated at 100W USB C PD standard .
Can be purchased from Shopee for only SGD $6-7 per cable .
I do have a couple of USB-C chargers lying around ( including my car) so I bought over 10 of these cheap USB-C cables just for charging.
The Ugreen brand has some right angled ones that you need.
These are cheap because their data transfer speeds are only 480 Mbps speeds.
2. Data Transfer
Cables rated for high data transfers are usually much more expensive.
For that, I suggest getting your cheap cables from Amazon.
To ensure that your cables can support fast speeds, cheap Thunderbolt 3 or TB 4 cables can be purchased.
Amazon also sells cheap USB 4 rated cables. Eg Riitop brand or their Amazon basics brand .
Average price is around USD $15 per cable.
I seldom do data transfers so I only purchased 2-3 of these.
They are expensive but can also support at least 100W charging too.
Ok will check out ugreen.
I only need to transmit data for carplay
Used to buy orico but it now become quite expensive
aha8
If anyone looking for slim minimalist design with action button cover, lens cover and magsafe. However, offer little to no drop protection. 😞
Hoce Ultra Thin Frosted Magnetic Phone Case
我要买GTR
Anyone has other working USB-A to USB-C cable working for your Carplay other than the Belkin cable some bros mentioned? Asking for a friend 😂
Anyone tried with UGreen?
trd2970
I was just using a random USB C cable I found at home, think it came with an old Huawei 15w wireless charger. Works like a charm with CarPlay. I think the data transfer speed requirements for CarPlay is not very high.
runforyourlife
Moderator
Moderator
Issit? Belkin to me is premium lei. See the 3-in-1 charger...
