iPhone16/Plus/Pro/Pro Max Accessories Thread
cloudystar
The problem with Benks is that their QC is not really good. It's really up to your luck whether you get a good quality case from them or not.
I bought a few times from them in the past and have encountered fitting issues, loose camera rings etc.
cloudystar
hahaha, how long have you used it?
My personal experience is about 2 to 3 months then the yellowing gets unbearable.. :rolleyes:
cloudystar
Phone Rebel has finally released their much awaited Gen6 Ultra with the camera control.
Based on first look and early reviews, it's really really good. :D
cloudystar
Rich (BB code):
The conductive copper pins in the design of the camera control cover looks to be the same as Supcase?
It's not the same as Supcase. The copper pins for the Gen6 Ultra are actually hidden. The inside of the camera control button is a white soft material that likely won't do any harm to the actual CC.
dyst09
Phone rebel gen6 is so chio. but too bad its magsafe case. anyone have any recommendations for case with higher than normal camera protection for ip16 pm but without magsafe?
quite difficult to find. anyone have any recommendations?
ragnarok95
Senior Moderator
Senior Moderator
Nothing to play. Bought the original apple silicon casing since i tried out in Apple Orchard and quite like it.
ragnarok95
Senior Moderator
Senior Moderator
I bought the stone grey one. Fits quite nicely also. I have been using the Spigen hybrid T since i got my 16PM and it's such a wonderful case. It feels solid and strong. Now i moved to this silicon case, i can't help but appreciate the simplicity and minimalist design of this casing. Makes me fall in love with my 16PM all over again.
