- Mar 9, 2004
Action button is covered. Capture button not yet. Thats's why i didnt invest so much in my casing yet.
they r only given the mock up/dummythese third party case manufacturer don't need actual product to test before manufacturing their case ?
if u order from uag website its 99 usdCurrently using uag monarch pro carbon fiber for my 14 pro for 2 years.
considering if should buy monarch pro Kevlar for 16 pro. The red stripes look cool. But case is $153
or should I look at other cases cos already using uag?
I added to cart, cart empties by itselfif u order from uag website its 99 usd
, u can email them for a discount voucher whuch they will always give 15%
after 15% will be 85 usd whucg adds up to 120+ sgd
plys they have member points cashback for subsequent purchases
don't buy from local distributor tech house damn ripoff
i just ordered mine this way
email for discount code firstI added to cart, cart empties by itself![]()
Do you have magsafe accessories? According to spigen website even their non magsafe case is compatible with wireless charging so if you don’t have magsafe accessories can try regular case as long as its not too thick.better to buy case with magsafe ? or
i nv use magsafe before so not sure how useful is it. i seldom see ppl use too.Do you have magsafe accessories? According to spigen website even their non magsafe case is compatible with wireless charging so if you don’t have magsafe accessories can try regular case as long as its not too thick.
Me too. Well i guess if one has many magsafe accessories it makes sense otherwise what’s the point especially when its slower than wired charging. And the argument that its neater & less cluttered isn’t true as the magsafe charger also has a power cable and depending which model you buy, something like belkin 3 in 1 looks like a small tree & takes up lots of space too.i nv use magsafe before so not sure how useful is it. i seldom see ppl use too.
monarch pro kevlar broi nv use magsafe before so not sure how useful is it. i seldom see ppl use too.
