Swordsman
- Jan 27, 2002
can i book ippt some other time and not take IPPT during ICT?
can as long as before your window is closed.
You MUST take your IPPT during ICT as it's part of your ICT programme. Doesn't matter you pass or fail, they just need your attendance.
doesn't matter if i pass or fail? but failing means going for RT right?
Tomorrow I going for my IPPT, what must I bring? water bottle and 11B?
is there a locker to put my staff, I intend to book in civi, then change to PT kit
Hi vasilli07,
I've booked 10 sessions of ipt at maju. Today was supposed to be my first session but i forgot about it. Do i have to do a make up? Or does my supposed 2nd session becomes my 1st session? Will my ipt ippt still be on the 8th session i booked or will it be moved to the 9th session?
I'm still under the old system, so I am only required to do 7 trainings and 1 ippt at the end right?
Under this flexible booking system, do i have to strictly adhere to my booking timings or can i just go as and when i can go as long got 1 day rest in between?
Thanks in advance!
Thanks! That cleared a lot of things up.
Does this mean the 9th session i booked becomes my ipt ippt? Because i realised in-pro timing for ipt and ippt different.
ok, then wait a week or 2. If still haven't update, call ns.sg.
And you don't like even numbers, what happened to the even numbers receipts?![]()
thanks man, you really do know alot about ipt/rt/ippt! you sure you're not some regular-in-disguise? Lol.
ns.sg just updated my status today after 1 week. cleared ipt for the entire year![]()
Hi guys.. i booked my IPT schedule tml evening... From my NS portal.. i can see that it says "The enhanced new IPPT system will apply to you from 06/10/2011 onwards."
Does this means i am still in the old system whereby only need to go 7 IPT plus one IPPT session?
