IPPT, IPT & RT Questions...
cct75
Hi,
I'm excused one station, my vocation is combat.
so my passing grade is d+10 right?
If i score 11 but fail one station,am I eligible for partial retest?
Combat is D+10? I am under Service already D+10 leh.
If you score 11 but fail only 1 static station, you should be eligible for re-taking the failed static station. If you failed 2.4km, you have to re-do the 5 statics stations plus 2.4km again.
Hi,
What is the ippt cat test like?
Just the 5 stations?
All 5 stations plus 2.4km. This is to "judge" your current "fitness" and use to gauge you to see if you have "improved" after the IPT/RTs.
So, if you are smart, you should purposely do as bad but not too "wayang" as you can so you can easily "improved" on the actual IPPT test.
cct75
Just like to clarify one question...
I'm going for IPT this Sat, because i defaulted on my last IPPT window. I understand that the first IPT is a IPPT banding test. I'm rather confident of getting a gold.
If I get a gold/pass on my first IPT, does this mean that I do not have to do anymore IPT? Or must still do 7 IPT + 1 IPPT on the 8th session..
Hmm, if you are confident to get gold, y not go for another IPPT and get the $400. Usually, if you default the previous window IPPT, you would not be eligible for IPT but rather than RT right?
cct75
Strictly no mobile with camera. We will go after you. No mercy when caught. Be warned.
LOL. I always smuggled in my Camera phone at Khatib FCC not that I will use it inside the camp but more to lazy to keep it in the lockers at the guard post and got to retrieve after outpro. I even once bring in PSP and played on IPT-IPPT session which I always arrived as earliy as I can to be sure to be among the first 40/50 number so can be in the first batch to complete 2.4km.
Again. SAF Rule #1 : DO ANYTHING YOU WANT! DO NOT GET CAUGHT! :D
cct75
Hi, newbird here, needs help with some questions. I am under the old ippt system. My current ippt window starts from dec 2010 till Apr 2012. I am very sure that I can't pass my ippt. My question is if I go for IPT this year, would I be exempted from RT? Or is there such a thing as I attemp 1 ippt this window and opt for ipt instead of RT for my next window?
How come your window so long one arh? Not Birthday this year to Birthday-One Day next year eh meh? Have you owe SAF any RTs?
If not, I am guessing you can join the majority of us purposely book your IPPT but failed it which by right you will be "penalized" with RT. However, SAF is given a one-time free conversion of RTs to E-IPT/RT so at least this year, you only need to commit one session and next year than join the majority to take E-IPT (10 sessions) + RT (8 sessions).
xerref
Thanks for the reply.
I called up the ns hotline and was told that normal combat is d+12. H/e, if you excuse 1 station its d+10. Had to call them twice to confirm cos when I was at maju, I was told that I still must get d+12 despite excuse.
super_marvel
Bros... I've checked up NS.sg & they mentioned that obese NSman can join E-IPT & have weight loss set as PPT... is this true or not? And is it attainable? Any 1 who's attending this can share?
Cuz I got I need to take E-IPT/RT this year, but might be skipping RT cuz I don't want to do 40 sessions in my this birthday year..
joneeee
Oh, I used the option to convert all the RT to IPT, for the simple reason that the IPPT is held at the end of 8 IPT sessions. The IPPT is held at the end of 10 sessions for RT. Since I'm quite okay with passing, I just switch to IPT, so that I can save 2 sessions.
Really quite a pain to default manz. I didn't know default one time will get SAF 264. I thought at most just book RT and clear it. zzz :(
temasekcity
Why take the risks?
visissss
for obese personnel, ipt will be gauged as weight loss programme. If you meet the targetted weight loss at the end of 10 sessions, you will be excused rt/ippt for the rest of the year.
However, you are not expected to gain back weight, so your next window may not be applicable for this programme. (PTI did not clarify on this, so im guessing)
goenitz33
Need help from you guys, just completed my 1st session of IPT-IPPT( new system) , i did not meet the requirement of PPT 1 which is the entry level for my 2.4km run, so which band will i be in and which level i need to obtain at the 10th session in order to pass this new IPT system?
so which level did you fall into?
or they just put you inside level 1?
temasekcity
Well done and smart move!
You are classified under no band and your target this year is Band 1. Don't be too smart and break Band 1. Keep on training. More good health!
cct75
Why take the risks?
As I said, DO ANYTHING U WANT as long as you dun get caught. So far, for my previous 3 years IPT of 8 sessions (aka total of 24 sessions), I always bring along my Camera Phone but switched it off and keep inside my bag in the locker at the FCC. As long as you do not opening use it to attract attention, I see no harm.
Even regulars in camp I see them using Smartphones, BlackBerries etc with camera. I am not a new bird so I know what to expect.
temasekcity
Dude, if you play with fire, make sure dun get burnt. Why not dun play fire in the first place?
visissss
Camera phones are generally not allowed in the camps, but you can put them into the lockers provided. As long as you do not take them out/use them, there will not be any problem.
starqwerty
Hey guys do you know what time does the ipt on sat usually end? It states at 730? Any chance earlier than that
visissss
depends on which fcc you go.
for bedok fcc.. usually 4.30pm start inpro for RT personnel.. for ipt personnel only at abt 4.45 to 4.55 then can get to inpro.
will end abt 7pm usually.
rasfene
Guys I'm trying to book my rt @ maju but realized there's not enough slots within the 2 months in maju. How? Must book @ other fcc to cover the rest? Or can go any other days to complete without booking @ portal?
