IPPT, IPT & RT Questions...
monster23
hi bros, I'm currently under the old ipt system and already attended 8 lessons including ippt however the system in ns.sg still reflect as non complete. Does it take some time for it to be reflected on the website or something or do i have to call and enquire about this?
vasilli07
Is your schedule date over? If no, please wait a week or 2 after it's over and your status will change to completed ipt. Remember to keep your attendance receipts till your status is changed.
goenitz33
Actually, all IPT/RT first sessions will be CAT-Test and report at the usualy time (18:00 for RT / 19:00 for IPT). Only the actual IPPT sessions need to report early. SAF again screw-up and even the NS-Men CS is so blur.
read through alot of pages just to get this information.
Thanks :s13:
Bonafider
Is there any penalty for not turning up for a booked session of RT?
I've pre-booked 14 slots and attended 6 so far, coming Monday being the 7th session. Problem is I've switched my degree course to part-time and the lectures start next week, possibly going to clash with the prebooked RT dates. Not sure if missing/cancelling a session will work since it has repercussions (ie the following sessions' RT-IPPT requirements will not be met (falls on Sun/Mon)).
A 'fail-safe' method might be to wholesale cancel all future RT sessions and 'rebook' them again. But I'm afraid it might compromise my ability to get the 20 sessions booked within stipulated deadline. (I'm given a month's extension till 4th Sept)
Please kindly advise. :(
temasekcity
try to rebook them them online. the date availability is scare.
xmartin86x
Hi all,
I'm NSmen. I've just taken my ippt just now and failed. My window closes on xx/07/2011. So i definitely in 20 RT sessions or i'm able to convert to IPT?? Read the NS portal, and i dnt really understand. Pls advice. :)
vasilli07
Hi all,
what does your ns portal says?
xmartin86x
If fail, go to 20 x RT session frm xx/07/2011 till xx/12/2011. Hmm..can i convert to IPT? They also state that the new enhanced IPPT sys starts after my bday. So i'm unsure if i'm in IPT or RT..
temasekcity
Hi all,
Just take RT since you failed.
vasilli07
You should be able to convert it to IPT for this year. To double confirm, try calling ns.sg to check.
rEe_TaN
Hi Vasilli07.. I miss my thursday RT lesson but if i apply for a makeup lesson.. will i be okay? I know the new rule that we cant skip any RT sessions anymore..
junny1
Enquiry
Hi, i have an enquiry here. My bday is Jan 10. then erm i have just finished my first in camp. there is ippt in this in camp and they say if pass, can use it for the current window. but if fail, can go book again before ur window closes. so if i dont book another ippt again, since i already failed, then next year when my window open can convert to ipt right since i have rt at the start my next window after 1 APR 2011? or i still have to book another ippt session?
