Nope, in their context, they will give you a time slip from 6pm-10pm by default.
swee ah..
then the ns.sg will automatically update by itself after all 8 sessions completed?
keep the time slip in case ns.sg cock up?
oohh.. so IPT around 2h ? or ard 2h 15min like that?
alot of pple will fail ippt hor ? i scared i only one, cannot pull, cannot run..
yes...like i say, may even end earlier depending on how 'kind' your pti is...
yes...will have alot of failures..
hi guys got a question. im currently attending rt for failing my ippt last window so if i wan to skip rt for my current window i should do a ipt after my rt ?
thx vasilli! wah siong man like this lol
just to confirm for the "2 sessions/3 sessions" that can be missed in phase1/2, does it matter which sessions to miss ? im thinking of skipping the ippt test sessions. is it a must to attend the ippt test sessions ?
thanks ! i shall jsut skipped those ippt sessions den![]()
I tot one MUST make up for watever session he missed in whichever phase? If dun need to make up then everybody will most likely just skip 3+2 sessions across the 2 phases mah?
just wanna ask..
bedok camp .. if i go from tpe at sengkang.. which exit do i exit thats the nearest to bedok camp?
