IPPT, IPT & RT Questions...
Serblime
my b'day this dec and ns portal say enhance ippt / ipt only apply to me next yr. i already cleared my 20 rt this year for last yr's failed ippt.
portal still ask me book and clear my ippt for this year if not can book ipt by end of dec before my b'day. but frm what i read for the new enhance ippt system i can hav one-off opportunity to convert remaining rt during transition which means even if i haven't clear my ippt for this year i can just go book ipt from next year onwards am i right?
ok make it clearer i dun know if i'm right.
this year take it i fail ippt. my b'day end of dec. so which means i owe them - saf 20 rt for next year startin jan 2012. but then leh portal says i can hav 2 options, either attend 20 rt + 20 rt = total 40 rt or can convert 1 off to option 2 meaning take up 10 ipt session within first 9 mths or before 6 mths if can pass ppt then done liao. tio bo?
Serblime
oh and if my last ippt test results all 0 pt or E / F score for all station and if i were to hav same results for my first new system IPT cat test which means i'll be at ppt entry lvl 1 right?
will the ppt level go up year by year if my performance results for the ippt always the same every year?
Serblime
oh btw anyone go for the new ipt yet? i think most can clear ppt within 2 sessions right? or earlier than 10 sessions...
vasilli07
Yes, you should have a 1 time conversion. But I believe you would still need to attempt an IPPT 1st as your annual attempt. Just like even if you want to go for RT, you will still need to attempt an IPPT once to avoid being charged as a IPPT defaulter.
Serblime
attempt liao la. i just need to pass this yr which i can't. my rt this year attempt 3 times liao. even portal also say 'pls pass yr ippt'. but it also say i attempt liao. if i never attempt they will put pls go and attempt mah
vasilli07
then it's a standard reminder as you have yet to pass...so just ignore and wait till your window close.
dani3l86
Hope someone can enlighten me here... I just ORD few weeks ago and decided to take IPT and my first lesson is tmr... Just a few questions here...
1) Attire for entering the camp must be long pants and not PT attire? PT attire can be non-SAF clothes right?
2)How to I know where to report for the IPT-IPPT, i mean there will be many people around for normal IPT training
3)I just ORD and this is the first IPPT so my PPT would be Phase 0? Tmr should I try my best and fail, or just relax relax do so my PPT will not be set too high
4)So how do they know I have reached my PPT during the 2-9th lesson? I need to book a non-ICT IPPT session on my own? What if I failed the IPPT session?
5)If i achieved the PPT during the 10th lesson, let's say my PPT is all set at Phase 1 (not enough to pass IPPT which is all above phase 2), do I still need to attempt IPPT after PPT?
6)If i achieved the PPT during the 10th lesson and the scores are enough to pass IPPT, do I recieve the $100?
arcturuz
My friend say for the 1 time conversion of RT to the new IPT, you can only do it during the first month after your window close i.e birthday 15 August, can only convert to IPT from Aug 16 to Sept 15.
after that cannot convert, can only do RT, is this correct?
darklighter
Sorry if this has been asked before
why PPT4? i thought it's stated PPT1 as entry level, and an increase each for following year IPTs as long one is within the same Age CAT.
Is it true a change of age category resets PPT 3 to 1?
chainer9999
u can enter in pt kit. no slippers
u just tell the counter ipt ippt else just ask any pti
ur 1st ipt is a cat test to see which ppt u r at
yah book on ur own. fail means continue with program
pls rephrase qn
not sure. but i tink no
Serblime
becos 1st mth by right need to start clearing yr 20 RT already mah
then if u dun convert leh last 3 mths of yr window another 20 RT haha
total 40 RT. can make FCC yr home lol
Serblime
ppt diff from ippt la bro if u attend ipt why u still bother abt ippt when the ppt is already set for u at entry lvl 1? if u wana kay kiang ippt then go for it lor. if not once u clear ppt 1 then no need to attend liao mah
Serblime
what i still dun understand is whether they will increase ppt from year to year then eventually will be at ppt4 in 4 yrs time jin sian
NatureKeeper
sorry bro, 1st 9 months of window is for IPPT and IPT only
last 3 months of window is RT
so u complete IPT 10 sessions then wait for 3 months before your birthday and proceed with RT 8 sessions.
ok...thanks...got a rough idea now....
Rknight
one quicky question, this cycle is my first time booking IPT. I want to go for IPT, under the NSportal should I book IPPT or IPT ? I understand first and last session of IPT is IPPT. But since this is my first IPT session, which should I book ? Because I am afraid if I book IPPT, it is not linked to IPT. And if i booked IPT, it will not be an IPT-IPPT session but a normal IPT session. Any they have IPT-IPPT session on saturday too right ? Thanks.
