IPPT, IPT & RT Questions...
Pryson
sorry for my noobness i just went through my ns portal again
my 1st session is a IPT ? means i cant go right since i nv go for ippt?
Pryson
Don't go. Just go for wed session.
Omg, my birthday is 1st june 2011. this feb is my last month to book IPT .. if i skip tmr i cant enrol to ipt liao. so go for the IPPT lesson and go for the RT instead from march to june? 20 sessions? no choice le right?
i just upped pes last yr so very last min sian
vasilli07
Actually you can try going, then you just tell them you don't know today got no ippt lah. Then they will tell you to take your IPPT on the 2nd session instead. I see people doing it before.
Pryson
bro but according to the pic I showed. my second ipt is not a iPpt session. can ah? thanks
vasilli07
Like I said, you can try acting blur, say you don't know lor. You also got no choice now since you also cannot rebook a later date, right? Might as well try your luck, I seen pti asking other people to do their ippt on their 2nd session.
Pryson
Ok, thanks for your advice bro. Pardon me first time taking IPPT. I can't cancel my tmr session in the system anymore. Should I not go, who must I inform to cancel?
I have read about the IPT standards i can't reach the Band 1 standard even which I need to go for another 8 more RT after my 10 IPT.
I was wondering if I attempt 1 IPPT session this month. I will have to go for 20 sessions from march to June before my window close ya? Cuz I book 10 IPT for one month quite siong cuz I was thinking 3 months split 20 sessions more make more sense?
I'm curious why ppl got for RT instead of IPT?
vasilli07
No need to cancel or inform.
Yes, you can just attempt an IPPT and fail, then wait for RT.
Pryson
Should I take IPT-IPPT or IPPT. I was thinking to achieve band 1 cause I have never taken IPPT since 2008 till now.
If I take IPT-IPPT once I can book few days later for another IPPT session to achieve band 1? possible? I call NS hotline. they say no such thing
vasilli07
Yes. Once they give u your band, u can book another ippt and try to clear it. Many peeps have clear ipt in 2 sessions.
Pryson
Thanks so much for your reply, got another question:
You have NOT TAKEN your IPPT for the period 25/11/2010 to 31/05/2012.
I have upped PES from C9L9 to B. my new window is 01/06/2011 - 01/06/2012.
What happened to my 25/11/2010 0 05/31/2011 ?
vasilli07
That window over liao mah.
vasilli07
Thanks much!
I have just cancelled my remaining session and wanted to book one IPT-IPPT. but no matter which date i choose, the TYPE is IPT. any idea? :(
It's correct, when you go, you will be asked to take the IPPT instead of going for IPT training.
