IPPT, IPT & RT Questions...
saysuzu
yup. after 1st ipt session, can book ippt and pass with ppt requirement.
wah lau, like thatr everyone who don't mind the money can just book the IPT and score very lousy on purposely. Then after that, 2nd session go pass IPPT with the PPT requirement easily, lol
should have done that if i knew that
vasilli07
Hmm....got a qns here ...
this year i fail my IPPT all 0 points, but I pass my target band PPT 1.
then next year I fail my IPPT again all 0 points, will my target band still be PPT band 1????
No, past year IPPT result is taken into consideration. So if you pass target band 1, next year auto is target band 2. If you continue to pass, you will eventually go to band 4 which is to pass your IPPT.
vasilli07
You are not guarantee the lowest band if you have done farely well the previous year. And once you pass 1 band, you will move up to the next bandl. So this method can't be done every year.
vasilli07
i mean ipt's ippt. can it be book? the ippt consider a ipt session
If you book a non-ict IPPT, it will not be considered as an IPT session. Only the 1st and last session(both these sessions are IPPT) are considered as IPT session.
vasilli07
My question is:
1) Don't i need to attempt another "Brand" new IPPT session due to the fact it's a new window already? (Meaning i will have to go for another set of 10 sessions IPT after my new window starts or i'm wrong?
Hope someone can clarify or help me on this, i got 3 diff replies from ns.sg. Sigh.
Thanks in advance.
Your case abit complicated, maybe just check with your unit instead. Call ns.sg and ask them to contact your unit.
sentsggirls
anything to bring for ipt-ippt ?
i am going today later at bedok fcc,
wear shorts and t shirt with slippers go there then change can bo ?
vasilli07
ic/11b/driving license
pls don't wear slippers when u go in, at least shoes
sentsggirls
so is wear pt kit with shorts and pt shoes?
can wear other t shirt go in ?
how much does saf pay me to attend my ipt per session ?
I am 3SG in Combat,
thanks anyone knows?
j_t_fusion
I am 3SG in Combat,
other t-shirt also can... but must be in proper shoes...
no pay for ipt sessions... got pay for the ipt-ippt session...
voiceoflove
I am 3SG in Combat,
ipt no pay
ippt $15 for each session first 3 booking only
Hi all,
im sorry if this question have been asked before.
i've ORD last year june , and my birthday falls on march .I have completed 1 ippt(failed) , first ipt(cat-test) and 2 other ipt trainings, now i think i can reach the ppt standard..but..
"You have NOT PASSED your IPPT for the period 14/06/2011 to 13/03/2012.
You have NOT COMPLETE your IPT for the period 14/06/2011 to 13/03/2012.
Your next IPPT window will start from 14/03/2012 onwards.
b) You are strongly encouraged to sign up for IPT if you need additional help to train for your IPPT. The first session must commence before 13/12/2011."
my question is , how do I book a ipt-ippt on my 4th session of ipt?
can someone teach me step by step..?as i clicked on the ippt button and booked one slot which is at 5pm , but there is a note saying ipt-ippt is on 7pm.
This(Please note that the new reporting time for non-ICT IPPT is 1700 hrs, RT-IPPT is 1800 hrs and IPT-IPPT is 1900 hrs.)
how do i book the ipt-ippt which is on 7pm slot that i want?
thanks alot whoever helps me :)
vasilli07
You can't book an ipt-ippt(unless it's the 10th session) at 7pm. To clear your ipt earlier, you must book a non ict-ippt(5pm) to do it.
You can try calling ns.sg and see if they do anything to help you.
sentsggirls
today i go for my first IPT-IPPT
next time i go will be 2nd sesion which is an normal IPT
so the book in time is 1900HRS?
whats is non-ict ippt ?
i try book IPT and it starts from 1900.
my options on ly have (IPT) (IPPT) (SAFRA-EPREEP 1 )
pls explain thanks.
vasilli07
pls explain thanks.
Yes.
Non-ict ippt means normal ippt lah, starts at 5pm.
SAFRA ipt must pay 1. $180-200 if I'm not wrong. You must book those at camps for free ipt.
meaning to say that..even if i booked a non-ict ippt, i can use the ppt standards to pass my ippt? actually timing wise is not a problem..what im afraid is the non-ict ippt i booked will be the normal standard to pass and not the ppt standard im in now .
zeframe
RT for 40 years old?
I am turning 40 years old in a month's time (early March). Am non-officer hence per enlistment act will be EX NS by my 40th birthday and free from all NS liabilities....but have not completed my FFI and IPPT for my 39th birthday. What happens when I turn 40? Will they still charge me and expect me to attend RT thereafter or let me go since I am 40 years then and free from all NS libilities including RT. Appreciate any insights/sharing. Thanks!
