IPPT, IPT & RT Questions...
KWSW
Wanna ask, since I failed to clear my PPT for this cycle, for my next cycle would the PPT remain the same or will add one?
guys, do i still need to do 2 more ipt sessions? i had cleared the last ipt-ippt liao, i din get notification to go next ipt yet
soulblader_86
if I fail every year didnt meet PPT also band also +1
what the point?
since it is very obvious that I cannot pass even the minimum, if they +1, make it even hard for me to pass....:s31:
I always tot if fail IPPT, I will remain as band 1
j_t_fusion
what the point?
if you fail your ippt but clear your target band, they will +1 your band...
KWSW
i think its more like for those who cannot meet the target band, whats the point in +1 to the band when the original one already cannot hit...
kaisoz
Moi was able to convert RT to IPT, and able to finish IPT a while back. Cleared the PPT, without needing to go for 10 IPT sessions. No idea what band I cleared. :yawn:
Now I read about this +1 band thingy. Sibei sianz man. Confirm boh? :(
How do I double confirm which PPT band I passed? All I received is an SMS notice saying I cleared my PPTs. Moi is considered those borderline case. But in the first IPPT CAT test, I ran > 16mins, so should have started at PPT 0 and target is PPT 1.
But based on what I ran for the 2nd IPPT which I did in ICT (at that time I fully aiming to pass IPPT, not just PPT, even with absolutely minimal training, but just failed by over 10 secs), I cleared PPT 3 leh.
So with the +1, my next IPT, I must clear PPT4? :eek:
Kiwi8
Deluxe Member
what the point?
They precisely dun want u to drag your feet over it.
Either u clear your PPT or u wash your ass to do the RT (sorry for being crude here, no insulting intended). :(
Kiwi8
Deluxe Member
The +1 depends on neither IPPT pass status nor PPT pass status. It +1 in the next window no matter u pass or fail. :(
soulblader_86
yea lor....like that wat the point?
might as well dun add in the those band thing...:s22:
Kiwi8
Deluxe Member
Most likely.
If u wanted to do just a +1 PPT in the next band, u shouldn't have done too well for your last IPPT session. Now that u are almost near the IPPT levels, most likely your next target PPT is 4 liao. :(
j_t_fusion
taken straight from ns.sg...
Q12 Will there be other considerations to determine my initial PPT level other than the IPPT CAT test results?
Your previous IPPT results will also be taken into considerations. You are only allowed a maximum of one drop in PPT level between the IPPT CAT test and your previous year IPPT results. For example, if the CAT test results determines a PPT level 1 standard but your previous year IPPT results is at PPT level 4 standard, your initial PPT standard in IPT will be at level 3 instead and not level 1.
soulblader_86
a small tips for ppl first going maju do IPT, dun come at last minutes
if not very hard to find locker
usually locker is all taken by the RT ppl...some r spoil 1...:s22:
kaisoz
Most likely.
Just logged in to check carefully, which I didn't do.
Doesn't matter liao, it seems, cos moi is already less than 6 mths to the start of my next window. So meaning no IPT for me. Its IPPT or RT liao.
But even then, this +1 thingy is absolute NONSENSE!!! When I go for my next IPPT, confirm will ask the PTI how the entire IPT system works and how they calculate, or whether its based on unit one.
Because if this +1 thingy exists, means I forever no need to go IPT liao lah :s22: if next time I opt for it, since I have to clear PPT4 which is basically IPPT pass level liao mah.
