IPPT, IPT & RT Questions...
vasilli07
I just logon to NS Portal again.
It says:
You are currently in RT phase. You have the option to opt in to IPT by 08/08/2012. Please note that you cannot change back to RT once you have made a confirmation of IPT/SAFRA E1 PEP booking.
I haven't attended the first RT session yet. So, what is the recommendation? I definitely preferred to attend only 10 sessions.
If you want shorter, then choose IPT. Not paid though. RT is paid.
vasilli07
does any1 knw if absent the sys will barr u from booking
If you mean IPPT, yes. 3 times u book(and never cancel in time if you cannot go), u never attend, you will be barred from booking. If you have yet to attempt, then you will be charged as IPPT defaulter.
Rknight
Hello, I have completed 8 lessons of IPT. My last IPT-IPPT ( 10th session) I decided to cancel the booking and postpone it to few weeks later. But the system doesn't reflect my 10th session as IPT-IPPT, but showed it as IPT. Even my 11th and 12th sessions I booked in advance all showed it as IPT. Probably a programming mislooked by mindef ? Should be safe and go for the 10th session as IPT ?
Second question, I know i have attended 10 sessions of IPT. But till now the time slip we get after the end of IPT still showed I am lagging at 3 sessions behind. However the nsportal did show the accurate pictures of 10 sessions attended. We can safely ignore the time slip ?
vasilli07
Yes.
Correct. The attendance slip do not take into account your cat test and IPPT. For eg, your 2nd session will be reflected as session 1.
plmokn
any one can give an insight what RT sessions does?..... can only do running for the RT sessions?
Elspeth
how bout ipt or rt?
vasilli07
Cannot only do running but can focus more on running training. Just tell the PTI/admin you want to join the running group
Kiwi8
Deluxe Member
It says:
Well, if u are very confident of either meeting the PPT or if u are the buibui group (BMI 25.5 and above) and are confident of meeting the weight loss target, then it might be best to go for RT, cos u can 'graduate' from the programme once u need the target and clear your window at the same time. Not to mention, RT is paid.
Kiwi8
Deluxe Member
Similar to IPT, there are also 4 groups for RT.
Green tag: Weight loss group
Blue: Failed both 2.4 + any/all static stations. Exercises will be on both running and static exercises. Known as Static + Running Group
Red: Failed 2.4 only but passed all static stations. This is also known as the Running Group.
Yellow: Passed 2.4 but failed any static station. Known as Static Group
Dracoira
dunno if its the right place to post :look:
i just came back from my ns medical
pes C9L3, remarks: excuse bmt
i failed my napfa do i need to go in 2mths earlier?
whale86
Hi all, will be going for my 1st RT session at maju camp tml. For the 1st RT session is it still 'briefing & outpro early' session or join in the group for normal session?
MrCoolStoryBro
i just convert my rt to ipt for this transition period
just went for 3 ipt sessions and i feel tt i am able to clear my ppt,
if i were able to clear my ppt, do i still need to clear the remaining 7 session of ipt since it is a converted case?
vasilli07
I don't think so. You most prob just need to book a non-ict ippt to clear your ppt. But call ns.sg to double confirm.
dante-z
You have NOT COMPLETE your IPT for the period 02/10/2011 to 01/07/2012.
means i must finish all 10 session before july ? if i book every saturday except for first and last session still can make it right ?
