KWSW
- Jan 1, 2000
yup it usually is. Can double check at NS.sg webbyIs the last session of ipt ippt?
I believe your unit is organising an Ippt for the whole unit. Unless you are sick or medically excused, you must go and attempt. If sick, bring your mc to show your pc or oc.
Something weird happened.
It is not my bday yet and I got sms that new window open...and I already pass my ippt last year(I took the ipt-ippt).
Checked ns.sg and it said I already pass and new window only open on my bday this year...and my bday is 7mths away.
..i'm going to ignore this sms
hi guys.. need some clarification here.
- i ORD on 8 june 2011. (birthday 0ct)
- Required to take Ippt before 30 Mar 2012
-took and fail.
-today i log in ns portal, it shows that i am required to take ippt before 30 june 2012.
why is it so? anyone? so i do not need to attend RT?
When did u take the IPT-IPPT? If it was before April 2011, u may have taken the old system, which means u still need to pass in the new window.
bday was oct last year...failed normal ippt so took ipt-ippt and pass on jan this year.
I've checked my ns.sg portal and it says new window open on oct this year so as far as i'm concerned , the portal is correct and everything is ok just that how in the hell i got the sms is something beyond me.
I'm going to ignore it since the online record is correct...maybe someone entered a wrong phone number.
When you say that you pass ipt-ippt, are you saying you just met the ppt or pass the ippt with standard scores?
If it's the 1st, then they are right in sending you the sms to remind you to take an ippt as you have not pass. It's their SOP which of cuz can be ignored since you met your ppt.![]()
Hi all, may I know for the IPT-RT (8 sessions)
As I see the system allows me to book up to max 8 sessions, what will happen to the 8th session? Is it just normal RT session or IPPT (means I have to take together with the normal one)?
RT 8th session is IPPT. Finish can go home.
oic, so the timing follows the IPPT not RT right?
thanks in advance
Argh, I was on physiotherapy for 3 months and only the this month I can take my RT. Was told by NS Portal personnel have to request for extension of window at FCC. Anyone got more details?
erm where to check my IPT band ah?,can't find in ns portal,which section ah??
drop down menu -> check past ipt attendance
