if default RT 2nd time, is it still a fine or is it DB? got confused with IPT in lieu of RT and missed gng for the IPT since i know can take RT in last 3 months. anyone can advise on this pls? 1st time i default rt was let off with warning, no fine and all. now 2nd time like this what wud be the punishment.
I'm not trying to frighten you.
CMPB have already heard too many NSmen excuses (genuine or fanciful ones) for IPPT/RT defaults. From this financial year (yr 2012) onwards....
For first-timers, they will let you off as a verbal warning. They don't even need to hear you explain. They will let you sign and acknowledge on a piece of document and you can go off to book your IPPT/RT at the counter.
If you default for the second time, it will likely be a fine based on your last rank. Third time, it will be straight to DB. Better standby to take 5 days leave in advance as you will not be able to use your Hp during the summary trial.
I knew because got two NSmen from my unit kana DB free and easy tour. One kana charged 2x and the other one 3x. The NSmen who kana 3x lost his job because he did not informed his employer in advance about his charge.
The other one is a self-employed businessman. So no problem.
