IPPT, IPT & RT Questions...
vasilli07
Sorry first time going for RT here. RT die die must reach by 6pm? Is there any official document that I can print or anything which would help in convincing my employer to release me earlier for RT? If it makes any difference I would be going for Khatib.
Can print your ns.sg that you need to go for RT or call your unit and see if they can issue something like a SAF100 to show your boss.
Hellooo
Suspended
qn1: if ippt failed then must book ipt within 9months?
qn2: if after 1 session of ipt and pass, means still can get $100 and don't have to go for the remaining 9 session?
vasilli07
You don't have to fail ippt to join ipt. You can just sign up for ipt.
If you think you can pass, why join ipt? Just book ippt instead.
vasilli07
I just failed ippt today
Ok. You can still sign up for ipt as long as your ippt window is not closed.
If you pass, you exit ipt immediately and get the $. If you only meet your ppt, you exit ipt immediately.
FuzzyMuzzy
RT must reach 6pm punctually or got slight leeway? I want to see what's the latest I can afford to leave my office.
vasilli07
6.15pm latest, provided you are changed. Any later then it's up to the FCC to see if they want to inpro u or turn u away.
maisatomai
Will be taking ippt at Khatib camp. Will the side gate which is near Khatib mrt be open or must I go from front gate(the gate which is super inaccessible?)
j_t_fusion
even if side gate is open, still must go thru the front gate.
side gate only for ppl with camp pass.
maisatomai
Thanks.
Ippt can take again if fail or if first time fail must immediate go rt? After 7 years after ord this is my first time taking ippt
vasilli07
Thanks.
as long as window is not closed, can go for as many attempts as you like.
secondhaos
Hi, first of all, would like to thank all the guys here who help each other from the answers to the questions. :)
Next week's going to be the first time going for RT and I have a couple of questions.
1) I read that when we in-pro, we will have different tag colours. How do I determine which colour I should get when it's my first time?
2) How is the attendance for RT confirmed? Is it confirmed upon out-pro like after IPPT where they issue us the receipts?
3) For the 8th, 14th and 20th RT-IPPT sessions, is it true that I should treat it like a normal IPPT (in-pro and out-pro at IPPT counter instead) ?
:s22::s22::s22:
Devilsire
If my house is near Khatib camp do you think I can cycle inside? Don know where to park the bicycle too.
Can, there's bicycle stand at the fcc iirc. Just rem to have a chain or something to secure it.
:s22::s22::s22:
1) Based on yr ippt result, the inpro counter will assign accordingly eg. static , running, both, or weight loss.
2) Yep receipt
3) Yes normal ippt, but at RT session's inpro timing.
justme
hi, i have finished my window under IPT - Weight Loss
When my next window opens, if im still overweight, can I still be under weightloss?
jyajin
Eh guys I have trouble booking my 20 sessions of RT leh
My knock-off hours is 1830, the earliest I can be released is 1800
How da fug am I to reach Maju camp from Redhill station by that timing huh, still have to walk 15 minutes to station somemore
Really ish ganna ****ed deep deep loh, when did they adjust the timing until 1800 btw huh, really ish jin inhumane leh tmd
