IPPT, IPT & RT Questions...
vasilli07
you say you never take IPPT and kanna charge, now need to do RT, but why only 8 RT, you should be doing 20x RT
He wants to pass the IPPT on the 8th session, that's why he is assuming he will only do 8 sessions for now.
xxduckxx
orh! IC.. so kanna charge for IPPT .. ho kay understood .. thought its kanna charge for missing both RT and IPPT.. okok then will jus proceed to take the 8 RT and pass the IPPT then
thanks for the advice
fitlies
if i remembered correctly, to be excused from the current ippt window, you need to be on excuse in the current window continously for at least 6 months, or 9 months if the excuse is not continuous.
eg.
new window start on 29 june.
doctor issue 6 months excuse ippt on 28 june.
then you are not excused from the current window cos you are 1 day short of the 6 months excuse in the current window.
anyway if you qualify for the excuse, i think you still need to get it endorsed by SAF.
want to play safe just call ns hotline to ask...
so long it is 6 months, inclusive of the window I'm in?
About the endorsement, do I just go to my unit MO to get it done? Because I have not been called up for any ICT thus far this year.
j_t_fusion
as far as i can remember, the 6 months must all be located within the current window. any spillover to the previous and next window are not counted.
i not sure if can just walk in to the medical centre and ask MO endorse or must make appointment.
i strongly recommend that you give ns hotline to call and verify if what i said is still valid cos what i have said is based on what i can remember off hand.
fitlies
alright, thank you sir.
polke.
For the 1st & 10th session of IPT, will it be stated in the website as IPT-IPPT, or are all 10 sessions just listed as IPT?
vasilli07
It will be listed as ipt at 1st and auto change it to ipt-ippt on the test day.
secondhaos
Can, there's bicycle stand at the fcc iirc. Just rem to have a chain or something to secure it.
1) Based on yr ippt result, the inpro counter will assign accordingly eg. static , running, both, or weight loss.
2) Yep receipt
3) Yes normal ippt, but at RT session's inpro timing.
Went for my RT. Thanks!
reveton28
I was wondering does anyone know if ippt were to fail will we be able to still pop on the scheduled date or there will be delay? Cos i myself currently is in ptp batch, Ulysses coy. Just scared I can't pass ippt...
j_t_fusion
fail ippt will not delay POP but cannot get into command school...
reveton28
Oh i see...actually to go command school is for those that is aiming to become sargeants or higher is it?? If didnt manage to go command school will end up at where uh?? Wont be those xiong type is it?? Ps if i ask this kind of questions Cos im kinda blur abt it...by the way chances of not being able to POP on time is not so high am i rite?
larsime
if my window closes on 1 sept
but i am excused from IPPT till beyond that date
Does it mean I will have to do RT / IPPT?
vasilli07
u need to have 6-9 months excuse to be exempted from ippt. Anything lesser, u need to check with your unit.
jerald
Can i ask something:
If i didnt do my IPPT over the 9 months window, is my 8th RT session still a IPPT test?
Scherzinger
just wanna check
You have DEFAULTED on your IPPT for the period 28/08/2011 to 27/05/2012.
You have NOT COMPLETE your IPT for the period 28/08/2011 to 27/05/2012.
You have NOT TAKEN your RT for the period 28/05/2012 to 27/08/2012.
Your next IPPT window will start from 28/08/2012 onwards.
a) Please COMPLETE your 20 RT sessions by 27/08/2012, otherwise you will be subjected to disciplinary action.
meaning if i complete my 20 RT sessions before 27/08/2012, i should clear this window right?
thanks in advance, if it's true shagged ballz to me :s13:
vasilli07
just wanna check
Yes, u have to complete your rt by 27th Aug.
bengbeng
If submit MC during RT do i need to makeup for it?
If i need to makeup than might as well dont go and makeup on another day.
