IPPT, IPT & RT Questions...
Vertix
Hi all, need help and advise from you guys.
I'm currently on a 6 mths (84 days x2) excused IPPT and physical training status given by my unit's MO, due to a meniscus tear, till the end of september. My window closes on end of aug. Will I still be charged as a IPPT/RT defaulter?
I tried booking a ippt session previously and turned up at maju camp but was barred from taking by the PTI as I'm on status. So what should I do now when my status end in end sept?
I've not received any news yet from my unit or mindef so I'm not really sure what should I do next after my status.
vasilli07
Contact your unit via ns.sg hotline and tell them your situation, they will advise u what to do.
redcrosser
So far I go Khatib mostly, they dont bother to check for phones at all.
Wonder if Bedok will be more stringent in their checking, since they are Guards Camp.
the past few times i've been there, they do bag checks (a quick one) and ask for your phone. the bag check takes place once u step into camp.
anyone noe can wear shorts book in kranji camp 2 for RT
what type of shorts? you can book in with pt attire though :)
Vertix
I've actually called the hotline for 4 times and I've not received any call yet from my unit until now, so I'm kinda stucked at the moment. But thanks alot, I'll try calling them again.
vasilli07
Did u tell them that u want to talk to your unit? They should contact u within 3 working days after u called.
j_t_fusion
if i not mistaken, if you are on status contineously for at least 6 months, you can be exempted from ippt for the current window.
however, your start date of status to the end of your window is only 5 months so you technically do not qualify for the exempted from ippt.
i think you better keep calling them and ask them what to do.
KangGary
ask u all
i weight loss ipt
first day i take ippt and weigh myself
is the first day weight the starting point?
is it i mus go for at least 5 sessions before taking my weight again to see whether i meet the requirements?
vasilli07
ask u all
i weight loss ipt
They will brief everyone and ask those who think that they are overweight to go take height and weight. They will then record.
No, after 1st session and gotten your BMI, u can just stay at home to lose weight. When u are ready, book an ipt or non-ict ippt, go through it then take weight again. If u clear, u are out.
kaijie1981
If my 8th session ippt falls on a monday, wat can i do? Continue the rt an take ippt on the next session?
jian1986
can i know is my 2012 ippt debt clear if i cleared all 20 RT, even though i fail the 20th RT-ippts ? my friend told me that if i failed the last rt-ippt, i will kena another 20 RT, making 40 RT for 2012
Raider04
All RTs are to clear for last year failure in IPPT. So, 2012 RTs are for 2011 IPPT failure.
vangelis
Hi got a question, probably answer before.
I am doing full 20 rt. but in between skip a few. So need to rebook.
Which are the rt sessions that need ippt. Is it 8th, 14th and 20th session?
Are the ippt-rt compulsory?
