IPPT, IPT & RT Questions...
RazerDA
guys, i have a qns, if your window close on 1/1/2012 and you taken ippt and failed...you will need to go for RT. Lets say for the 3 mths of RT period before your new window opened which is 1/4/2013, you have an ICT in between 1/1/2013 to 1/4/2013
If you cleared your Ippt during your ICT, how would it be consider? pass and dont need to go RT?
vasilli07
Yes, you can skip RT if your pass your ICT-IPPT. But when your window is open in April, u need to clear again for your new window.
ahkiat
Sorry guys, first time taking RT and it's at Maju Camp.
So what's the procedure? Just go in and wait and get number tag? There's also people taking IPPT huh? How do I know which is which?
RazerDA
So i can conclude ict is a lifeline for you to skip rt if your ict fall witin rge 9-12mth window period? Do they specify this in ns.sg? Or u have asked them before. Thx!!"
vasilli07
U need to in-pro to get a number tag. Bring driving licence/11b/ic. Just look around the counter for RT in-pro.
vasilli07
Yes. But then, if u can pass, why wait till ict then take? So busy that u cannot afford 2-3 hours?
send0h99
having my first RT at khatib FCC due to default ahahaha.
any idea what's the RT procedure and how long will it take?
like run treadmill or gym stuffs?
vasilli07
Inpro with ic/11b/driving license. Change before inpro. 2 to 2.5 hours of training. Any later depends on PTI. Gyms normally for small groups. Yellow tags are usually the smallest group. Runs conducted on track or carpark.
send0h99
thanks! attire as in what kind of attire? must be singlet?
so long as shorts w covered sports shoe enough right?
anyway can't wear slippers into camp and change before session?
j_t_fusion
cannot walk into camp with slippers, walk out no problem.
if in car then any footwear also can.
top and bottom should be anything also can. i usually just walk in in shirt and shorts. i think i got see people walk in in singlet before.
chaotank
i'm at my 7th session of IPT, booked my 8th and 9th session.
question is, is there a difference if i take my 10th session of IPT (IPT-IPPT) and rebook IPPT again if i failed my 10th IPT
and
if i book seperate IPPT sessions before the 10th IPT?
would i auto be enrolled into RT if i failed my 10th ipt? or can i retake IPPT as many times as i like until my IPT window expires?
i foresee myself failing a couple of times before i can pass my PPT. that's why i'm worried abt booking the 10th session.
vasilli07
and
After you completed your IPT(10 sessions), if your window is not closed yet, you can still continue to book non-ict ippt to meet your ppt as many times as you like.
arcturuz
if my previous ippt result is band 3 standard and ipt cat test get band 1 standard, can allow a drop of 1 band rite?
vasilli07
No. It's always a +1. Cat test result will only be used if you don't have any previous result.
radiancez567
if after IPT didn't pass, go for the 3 months RT also cannot pass, what will happen for the next year?
