Is Cat 5e Lan cable still relevant?
novetan
Hi,
my smart Tv wifi kaput. So got to install lan cable. My speed is 1Gpbs and distance is 13m fr router. Can I still use Cat5e cable? Tks.
kandinsky
royfrosty
5e at that short distance is still fine. Btw your tv wont be able to saturate the entire bandwidth of 1Gbps. Tv the most even streaming of 4k contents are not demanding these days. At most pulling max 200Mbps at any given one point of time.
Hafi
I thought most smart TVs LAN only 100mbps nia?
cscs3
Hi,
More then capable. Just use it.
Elijahonli
if you are laying balanced cat 5E cables, then go ahead. if you are getting new cables, get CAT 6. it is not much more.
watzup_ken
I don't see anything irrelevant with with Cat 5e LAN cable. They are not the fastest in the market now, but still can transfer date up to Gigabit speed, which is going to be enough for most users. Especially for your use case to connect this to your Smart TV, it is highly unlikely it will be anywhere close to saturating the bandwidth.
wwenze
Air has not changed since the last 200 thousand years, yet we still using the same air for our wifi. :)
SkyShroud
CategoryShieldingMax Transmission Speeds Max Bandwidth
Cat 3Unshielded10Mbps16 MHz
Cat 5Unshielded10-100Mbps100 MHz
Cat 5eUnshielded1,000Mbps – 1Gbps100 MHz
Cat 6Shielded or Unshielded10Gbps up to 55 meters250 MHz
Cat 6aShielded10Gbps up to 55 meters500 MHz
Cat 7Shielded100Gbps up to 15 meters600 MHz
Cat 7aShielded100Gbps up to 15 meters1,000MHz
Cat 8Shielded40Gbps up to 30 meters2,000MHz
CategoryMax. Data RateBandwidthMax. DistanceUsage
Category 11 Mbps0.4 MHzTelephone and modem lines
Category 24 Mbps4 MHzLocalTalk & Telephone
Category 310 Mbps16 MHz100 m (328 ft.)10BaseT Ethernet
Category 416 Mbps20 MHz100 m (328 ft.)Token Ring
Category 5100 Mbps100 MHz100 m (328 ft.)100BaseT Ethernet
Category 5e1 Gbps100 MHz100 m (328 ft.)100BaseT Ethernet, residential homes
Category 61 Gbps250 MHz100 m (328 ft.)
10Gb at 37 m (121 ft.)
Gigabit Ethernet, commercial buildings
Category 6a10 Gbps500 MHz100 m (328 ft.)Gigabit Ethernet in data centers and commercial buildings
Category 710 Gbps600 MHz100 m (328 ft.)10 Gbps Core Infrastructure
Category 7a10 Gbps1000 MHz100 m (328 ft.)
40Gb at 50 m (164 ft.)
Category 825 Gbps (Cat8.1)
40 Gbps (Cat8.2)
2000 MHz30 m (98 ft.)25 Gbps/40 Gbps Core Infrastructure
Cable TypeShieldingMaximum FrequencyPotential Throughput
Cat 1No10kHz1Mbps
Cat 2No1Mhz4Mbps
Cat 3No16Mhz10Mbps
Cat 4No16Mhz10Mbps
Cat 5No100MHz100Mbps
Cat 5eNo100MHz1Gbps
Cat 6Sometimes250Mhz1Gbps
Cat 6aSometimes500MHz10Gbps
Cat 7Yes600Mhz10Gbps
Cat 8Yes2GHz40Gbps
Clearnfc
Hi,
Yes, cat5e is more than enough for 1Gbps or even 2.5Gbps up to 100m. Unless you live in an extremely huge house, it is unlikely that you will hit this 100m limit.
However, cat5e cannot support 10Gbps. You need cat6.
Cat5e and cat6 are very similar in terms of price today. No reason to go for cat5e anymore (unless you need lots of cables and cost is a concern).
yup even Cat 7 Cat 8 cable are affordable nowadays.
it's either re-use your existing cables or backside itchy go buy new cables.
Cat5e still works fine for 1Gbps.
Unless your router and PC Lan Port both supports 10Gbps.
Else there won't be any difference.
Clearnfc
cat5e and cat6 have the same 100m distance limit for 1Gbps/2.5Gbps.
