is it more cheap to use color laser jet printer or normal ink jet printer
hotamp
beside the toner, but lazer need to consider the drum as well, that one spoil expensive to change also.
radish
Emeritus Honorary Member
to me laser is better in terms of price and print quality.
NintendoSwitch
coyote
Just get a color laser. If you find it too expensive, just buy a second hand one from carousel.
DragonFire
It depends on the volume.
Higher volume = laser print is cheaper.
Lower volume = inkjet is cheaper
One thing to note is that laser toner is forever compared to inkjet ink. The latter dries up and clogs if the usage volume is very low.
DragonFire
I used b4 colour laser and the stupid thing is the printer will use colour to print black and white so u print black and white documents as per normal then soon colour ish bo liao like bleep man. Bleep. In case u thinking I bs u here ish link proving it.
https://help.brother-usa.com/app/an...-toner-usage-when-printing-in-black-and-white
End up after that, I bought new monochrome laser mfc instead.
Can't you force grayscale printing as default? I can on my HP. That uses the black toner which is cheaper.
johnsonheng
Yes. I went to sim lim to ask . They told me that. It set this way if not all the other color toner stock wont move as most if not all will print black only to save money on buying color toner
NintendoSwitch
Cannot. It will use your colour toner regardless of setting. See the link I attached. Also true from my own experience spending my own money to buy those toners.
johnsonheng
Not possible. I tried to remove the color toner from the printer and the printer will not print until the toner is put back in
johnsonheng
I don't have a choice. Some time I need to print color forms for chamber endorsement
jimboyboy
Go get a cheap laser printer like Brother. Moi never look back with that purchase.
Yes, I also got the cheapest Brither laser series. For replacement ink, I just buy 3rd party from Taobao at a cost of 20-30% of price of official cartridges. The printing quality is good enough.
But after some time, my Brither printer will print slightly sideways, ie. Not completely upright, a bit slanted. Is it the same case for you?
johnsonheng
I used about 10 reams of paper in one year
