... the PC shut down abruptly, then although the RGB lighting of the motherboard, the standby LEDs of the motherboard and graphics card are also on, the PC won’t boot up again.
Switched off the PSU and took off the power cord, reset CMOS ... then switch the PSU on again, hit the casing power button and the CPU’s HSF starts to spin again, but before the casing speaker (I fitted 1 of those on, still used to beeps
) beeps the HSF will stop spinning again, leaving the RGB lighting and standby LEDs on.
I have a brand new spare PSU (also Seasonic X750
) in the store room, so I took the 1 from this setup out and fitted the cables on the spare, and it boots up fine.
Does this mean the old PSU is dying? It’s not brand new, it was from another build previously although that build was hardly ever used.
If it matters ...
CPU : Ryzen 7 2700
Motherboard : ASUS Strix X470F Gaming
PSU : Seasonic X750
) beeps the HSF will stop spinning again, leaving the RGB lighting and standby LEDs on.I have a brand new spare PSU (also Seasonic X750
If it matters ...
CPU : Ryzen 7 2700
PSU : Seasonic X750
