Is it the graphic card problems?
Kightzzz
hey guys, My com had suffered the Blue screen of death.
So after in safe mode and uninstalled my graphic card, I can use as normal without any graphic intensive stuff, but when i finished re-updating my graphic card and restart it show me the blue screen again.
May I ask the pro here, if is it really my graphic card problems or something else? And if i just change the graphic card, will it helps?
Thanks in advance for any reply...=)
Thanks
bhtan83
Thanks
did u overclock ur cpu? if yes, revert back to default and see if the problem persist.
other hardware like PSU, RAM and HDD can also cause BSOD too.
Kightzzz
hey bro, nope...I did not OC anything. Just normal usage.
hmm bro, may I ask for some advice on how do i determine which part cause it?
Kightzzz
thanks for the reply again, yup..i upgraded to the latest driver...but same thing still happen...i uninstalled and upgrade it 3 times, while in between i scan for virus and scan for registry check...
Uno_Hu
I've just discovered my ATI HD 2600XT PCIe fan not working. Any solution to this?
