Is LUMOS Home Cinema Projector worth buying?? Really tempted to order nao!!
zheng
Any buddie bought aldy? Is it worth the $299 :s12:
I really tempted to buy one for my room :s22:
can buy... but pair with a android tv box better.... dun buy the one with the "smart" version... lousy as fk.
Lss
Tiong projector only got a few legit brands like xgimi, jmgo, Xiaomi.
Buy projector is got a lot of specs need to look into like lumens, contrast ratio, dynamic ratio, native resolution, keystone, colour reproduction, autofocus, throw distance, fringing and chromatic aberration of lens etc.
Any projector not from the major brands I mentioned above are likely OEM crap and Lumos falls under the crap category no matter how they claim to be different from the rest.
A good amdk/jipun brand like Epson, canon, viewsonic etc. even at lower native resolution can outshine OEM tiong crap advertising as 1080p native (which is most likely upscaled reso and falsely marketed as native). That's why they cost thousands and used in professional settings.
Too late bought a wanbo. Heng it is android 9 though.
Thought they use dithering techniques to increase resolution.
Supersen
Do note that LUMOS Auro cannot support WIFI 5GHz (7/7/2022).
i just asked them via facebook chat support.
Edit: Just checked on my router setting, new Singnet routers comes with either set to 5GHz or 2.4GHz but cant use interchangeable.
i think lumos is not bad a couple of my friends got buy. the Anker Nebula Apollo is also a good option, online like shoppee got sell can go see the reviews then consider
Supersen
was comparing Lumos projectors and Anker Nebula Apollo.
eventually went down to Plaza Sing to see the real gadget get Anker Nebula Apollo @ $499, after fave discount bought it $429
MadeInAnfield
I using lumos for 2 year plus already. So far I find it ok, daytime maybe not so sharp but night time it is enough for me. Price wise it is reasonable
Will look to try better brand if it spoils but it haven spoil yet
Ignatius J
malaysian brand Lumos cheaper
xcodes
top up a bit can buy a whole cinema for your own entertainment ...
wooooot
I am using xgimi laser short throw ... quite good :o except it cannot watch Netflix natively
wooooot
What does Netflix native means?
means if u tried to watch Netflix app on it, it will says it is not allowed
xgimi devices are not cleared by Netflix certification or something :
there are workarounds though
