CozyTheBest
Suspended
- Aug 7, 2020
yes, i agree too
Just to OT a bit...
I have been trying to find such services for PC but at a much deeper level.
Something like this
Where the PC is literally stripped apart from the heat sink and completely cleansed by spraying those liquid.
Just to OT a bit...
Something like this
Wah. This is expensive service.
Not only need to be knowledgeable about electrical components, but experienced and delicate to handle it like a professional. On top of that, you need the tools. What is that liquid he spray? Rubbing Alcohol? Not many dare to strip their gpu, voiding warranty.
In the end, it is just better temp. Not much use for non-overclockers.
For normal users, just pay the money to upgrade the parts will be more efficient way of improving PC performance.
Wah $80, come, I do for you. No guarantee PC will be 100% working, just that I will be as delicate as a flower to clean it. Haha. I do clean my PC myself, not to the extremity of this video, just basic dirt clearing, reapply thermal paste for CPU.
I totally agree with you. I am doing that lolbtw read your pm. thanks!
as for TS, you might want to give it a try to clean it yourself. It's not difficult if you practice with caution. just be gentle, use a can or airblower or as some bros here will suggest, grab a cheap blower which you can use in future.
btw if you intend to use those blowers, must make sure your PC is totally off and to tape your fan from spinning. reason is, when you are blowing air into the case. your fan will spin, this might generate backwards current back to your motherboard fan headers (harmful) so take note on that.
There is a risk element in doing this. I tend to do this on the PC's I look after but I am prepared to replace parts that can potentially get damaged in the process.
If you are really keen to do this then the cost will be pretty much the same if not slightly more than building from scratch as the person will need to dismantle and clean the items. If the PC specs are current then I would consider spending to do this otherwise not really worth it.
I have been cleaning my 2 home rigs as well as office desktops using compressed air.
For home rigs, using Metro DataVac. As for office ones, using company piped compressed air.
Got one time blow off the graphics card fan blades for office desktop.
https://shopee.sg/Sunto-ST01003-Mul...CitVTp4IlmIWv0WRFdKutZV7gB0pCgAxoCj8wQAvD_BwE
Bring the whole desktop out then spray the whole desktop especially the heatsink and fans
Be cautious using industrial compress air from compressor without air dryer, especially the air blower/duster at the end of the air pipe, water will collect at the end of the pipe, good luck if you happen to use the last air duster, you might actually shower you PC with water jet.
PC cooling fans won't generate current or became a generator if spin by external force like compress air or blower
