Is using hard disk drive cooler really useful?
flea_pepper
Does it help to prevent problems such as bad sectors due to overheating ?
Or it's just a waste to buy ? I'm thinking of buying if it makes a difference.
Elijahonli
i dont think it makes much of a diff. fan blow it, still will randomly get bad sectors. its all based on luck
Louisloo
It does makes a great difference in preventing overheating and heads damages.
It is particular useful when your disks have long period of activity, eg, copying large amount of data or downloading movies or being used in small servers.
mosmos
High Honorary Member
seems like will cool a little, my external HDD casing have this fan and it runs cooler than my main HDD~
WhiteHunter
not really useful. why not try improve your pc airflow.
alamakazim
actually very hard to say...
from my experience... my hard disk have not died in my Scythe Himuro Hard Disk Cooler... for past 5 years... 2 hard disk was used in 5 years
but I would say it does cool down and noise is damp with Scythe Himuro Hard Disk Cooler.... does it increase lifespan? is for u to believe
renclim
What about those NOT in the cooler leh :s11:
alamakazim
thats why... is up to u to believe...
cos there is no data to show, with or without got increase lifespan
cos all hdd have different usage
just make u feel better, or actually it does help, who knows
superzheny
If no longer in warranty than can consider buying a cheap one la :s13:
I think hdds are particularly susceptible to heat damage over time.
wwenze
What if I told you
The vibration from the fan that is screwed onto the HDD casing is more damaging to the HDD?
Nowadays cases already have front intake
noobiee
by the time your hdd uplorry from heat, i think you already upgrade several times
Valour
koreanlover
Think useful only if your HDD works intensively for long periods.
Otherwise don't really need it.
