Issue with setting custom ringtones
masashi
Hi, I have tried copying the m4r file and copy it to the tone folder in itunes, but somehow it doesn't copy. Is there any solution to it since copying music isn't an issue for me at all.
leongws
Set the ringtone(m4r file)to less than 30 seconds. Anything longer will not work
masashi
Thanks it finally worked! I'll keep this in mind next time I want to transfer another ringtone over. :love:
discoburg
Is there a tone folder in iTunes? You not using Mac right?
stupidog
With Mac you can't add custom tones anymore. Used to be able to do so when Mac was still using iTunes.
can ah, i just dumped in my custom tones via finder
plug in liao u go finder look for ur ipone, click it then it will open up something like itunes UI
go to music tab, just drag and drop ur m4r files in
discoburg
Yeah I jus did that 1 few days back. Googled and found newer and clearer instructions. I actually had to open the music app and not the iPhone in finder to transfer the file.
stupidog
ic, finder wan better. can see more stuffs
