Modify and cut the rear casing?![]()
i was thinking of doing so but price for china water cool is cheap....
you dont want to water cool your Ncase ?
Better not scrimp if you are really going for such unorthodox WC mountings...Ncase gallery usually branded stuff. I am looking for cheaper alternative China water cool.
Barrows should be okay bah.Better not scrimp if you are really going for such unorthodox WC mountings...
you dont want to water cool your Ncase ?![]()
Nope....No $ for custom watercooling.
Sold my H100i GTX before as the tube too tight for this case.
I just installed Deep cool LED & got my extra side panel.
Going to cut the panel & put clear acrylic.
Trying to do something similar to...
https://www.youtube.com/watch?v=oQBlkA8VKi4
i am looking for cheap one as long can work and no leak.
hope i scan squeeze every thing inside the casing.
i might consider this also.
image taken from here
http://www.overclock.net/t/1365342/ncase-m1-prototype-a-mini-itx-case/460
Hmm seem like not much Ncases user in SG....
Yesterday hoot! wc otw![]()
Is that Astro A40? The stand included in the box?
It is A50, stand included![]()
I’m looking for A50 gen 3 but all shops no stocks.
You using discrete gpu? I don't see it in the photo
Sent from LGE LG-H870DS using GAGT
First build
Case mod ongoing![]()
