Jetflo Case fan
tony_ong
Jetflo Case fan Problem
Hi,
i just brought a jetflo and somehow it seems to spin at more than 2200rpm on pwm when i set the bios for the fan "Target speed level 1 and target fan 55 degres". Then when i run the prime95, the fan spin just keep on increasing and all of sudden got weird noise coming from the fan.
When i look at HWMonitor, it shows 2800+ rpm.
What causes this? My motherboard bios or the fan does not limits itself to max rpm of 2200?
edit: Now even at low RPM there is some noise when the fan is in vertical position.
royfrosty
Hi,
Use the silencer wire.
tony_ong
now it seems like even when at low rpm even with the silencer wire there is a noise like brushing against something or some friction. not the fan wind pressure sound. :s22:
somehow it seems abit like the MB PWM caused the fan to spin at rpm more than what is stated by CM.
