kF94 or Surgical mask?
WussRedXLi
More testing on the Moleshi
Moleshi MIC kf94 vs mixshop MIC vs Blue Pine MIK KF94
Ambient 4k
leo2003
Hi guys need some recommendation. At present , wify is using F919, but stock is low. Have brought F929 black but she prefers white. Have consider F808 and looking at the measurement 205 x 80 seems ok, but in a previous post F808 is consider for larger face. F912 Blue pine is 211 x 82 so is out, She has sensitive skin, thus MIC mask i will avoid. Any recommendation. TIA
Ender
I am a regular user of F808.. Despite the leght is 205mm, is too big for women whose face is suited for F919. My wife and daugther wear the F919 perfectly, but finds the f808 too big.
Habrosus
Can consider F731 (economic pack of 50's) or F730 which is its individual packaging.
I've F731, F730, before I got 4-Ply Good Manner White (price on the higher side), then F919, Prism Black (but too thin so using only for outdoor/brisk-walking, and F929 as I was looking for some black ones for a change.
Primarily leave home using F731 these days.
Avoiding F808 and F912 as I feel they'll be too big, from what I've been reading here.
Edit: I use these mask stoppers to tighten whenever the need arises. Posting random link just to give an idea.
https://shopee.sg/-SG-READY-STOCK-M...0?sp_atk=5def9d25-4ebb-49d8-9df1-78957bee941b
Squaredot
Is F929 fitting for u?
Squaredot
bro, check something with u.
Recall u shared F912 is also big for your wife.
F912 Blue Pine is almost same length as F731. Is the height of F912 that makes it too big for her? Trying to understand the difference between the two..
Thanks.
Squaredot
I've only tried it once, the other day. I'd say the fitting is about that of the F731 but with a slightly bigger surface area? As in the total height felt slightly longer.
thanks.
do u find F731 slightly taller (looser) than F919?
Habrosus
thanks.
Yes, I actually do. But it doesn't really bother me, otherwise I'll fix the mask stoppers before leaving home. If I need a change when I'm outside, I'd just use without the stoppers if I'm on the move.
Ender
Thanks.
After she put on the stopper on the ear loop, she is able to wear it. F912 about the same as F731, just the longer loops makes it loose.
Habrosus
This looks like a good alternative to the rubber stopper. It seems easier to put on.
https://shopee.sg/Adjustable-Face-M...eless-Ear-Hanging-Rope-i.250741993.9860101315
Ah, easier to fix but only if you fancy having something dangling back there. I can barely feel anything with the little mask stoppers just behind the ears. 🙂
I got a couple of such mask lanyards from Shopee 10c flash sales but have never used them as I like to actually put my mask away whenever I remove it longer than having a sip of water, not hang it round my neck risking contamination.
ataurus
How about Tamsaa. It's comfortable for a regular sized face. Think loop lengths are ok. I bought 100 for $34 at a Shopee flash sale. Comes in 10s. But it's big for small faces.
Smaller cut masks are Heart Mom (sale on Qoo10; link shared by Ender some time back).
Other options are Nawell Medium, Plan Zero (black), The First Korea and Hoze Blanc. Last three sold by lyne_cosmetic on Shopee, among others.
WussRedXLi
Ya correct, like what ender has said, f808 measurements dont seem like big, but after wearing it you'd find it's rather big, predominantly is also coz of the slightly longer earloops (high change petite pax would need to tie knots) .
The "front panel size" also like a wee bit bigger than normal, so it would look funny on somewhat petite folks who find F919 just nice.
grynove
hello just found out this thread. im not really familiar with all the coding.
may i know which model is suitable for bigger face? recently i try kn95 from 3M my ears very pain due to the mask size
where can i find this f919. tried shopee and lazada can't find
Squaredot
do u keep your mask in something not to risk contamination?
Squaredot
no more F919 le, it's for smaller face.
As shared by bros here, F808 from Mezzang is for bigger face.
It's cheaper to use this normal price listing to apply $3 coupon from daily spin wheel.
$11.99 -$3 coupon=$8.99
https://qoo.tn/BocuuX/Q130011338
If no coupon, get from Time Sale is cheaper at $9.99
https://qoo.tn/BCduuX/Q130011338
WussRedXLi
For ears pain, actually you might wanna try mixshop masks first. They do measure ok (check back all 20 pages for measurements 🤙 :LOL: ), very similarly to the Made in Korea legit KF94s. Most importantly is that they have earstraps. Won't really have ear pain.
Try the yellow colour. I just verified it a few days ago. They are available on qoo10, shopee etc.
Or you can try the ubiquitous white colour, just that about 3-4 weeks ago someone sent me the 10-pack and it measured really bad (something like ambient value is 3k+ particles/100cc and i measured like 2k particles pass through the filter).
https://www.qoo10.sg/gmkt.inc/Goods/Goods.aspx?goodscode=608712224
Habrosus
This description sounds like my first and so far only experience with the F929, though my F919 is (I should describe as) tight fitting (which I rather like).
But F929 being thicker, it's easier for me to shape it like folding here and there, rather than just pull top side near my eye level and bottom side over my chin, which is more flat less space in front of my mouth. I'll have to find another chance to try it again, as black + 4Ply isn't an easy mask to use in our hot weather. I used it for indoor weekend environment back then. :o
