Lagging badly help pls
crystalnox
Aww :(
I've been using without changes till the problem suddenly occurs.
Will increasing the ram works ?
Running on 8gb now. Thought it would be enough as I use for LoL only.
Btw how do I reinstall windows ?
Do I just insert the win7 disc in ?
Windows 7 runs fine even on 2GB ram, 4GB more than sufficient for LOL. It's probably something you installed/accidentally installed that's messing up your computer. If you have the windows 7 disc just try reinstalling, can google for guides.
AnTiLooP
Aww :(
It's a simple process to rebuild but also depends if yours is branded or oem. If branded easy just call the support line to ask for basic instructions . On self build assuming you have the dvd just boot up with it and on onscreen instructions there will be options to reformat and install. Google for exact information.
That said it'd really a last resort. You should probably ensure you have no rogue apps running. Scan for male are and virus es. I remove what you don't need. Etc. Again Google for "cleaning windows" and you'll get a ton of articles on that.
diamond96
Thanks everyone. After reinstalling os the mouse cursor lagging is gone but the computer do load slower on startup. Could that be due to my ram ? Or is my hdd having too many files on it ?
I used 200gb out of 1tb
hengheng220
Got update for your windows? Since you just reinstall should have tons of updates or maybe your hdd old le?
aaaflyer
I have a rig built around 10 months ago. Recently when I use the computer it lags badly. I click and drag my mouse on the desktop screen to multiple select icons and when I pull the mouse it doesn't follow as it moves but there's a delay of 2 sec. What could be the cause of it anyone ?
hi, you can try this
Windows Repair (All In One)
install
go to the tap: start repairs
create a restore point just in case. the program will prompt u on this.
click all the options available, start repair.
it took me a few hours (ard 3h) but it magically fixed a similar problem which i had with my laptop a few month ago. give it a try and let me know if it works!
diamond96
EDIT :
The previous problem was solved temporary i guess.. When I reinstalled the os.
Now a new problem similar to it , when I clicked google chrome the whole screen blackout.
what could this problem be ?
HDD , PSU confirm no problem.
HDD run test before no bad sectors.
PSU was swopped to test also no problem.
Suspect RAM , is this possible ?
Or graphics card higher chance ? Using Palit GTX 650.
