Laggy Conqueror's blade experience
amirrudinong
Hey hi there,
I am currently playing conqueror's Blade Online and still, my specs have lag even at the lowest graphic setting having average FPS 30-40. It is a 15 vs 15 players game and open-world concept.
I can never hit 60. Even if I do get 60, screen shutters a lot, really little stability. Funny thing is- I've tested on other games and it all went well.
Witcher3 (constant 60fps)
Rometotalwar2 (60fps)
Hitman (100+ fps)
CS GO ( 250+ fps)
Just Cause 3(100+ fps)
If you could advise, these are my 2017 built specs:
Strix B250F Gaming
Geforce GTX 1060 6GB
Intel i7 7700 @ 3.6ghz
16G RAM Kingston, 2133
VX238H 60hz monitor
SSD 500GB
Eternet connection AC5300 router
Inside town,
my cpu usage is 53% and the temp is 71 deg.
Gpu usage is 63%, temp is 75-79 deg.
Normal startup,
my cpu usage is 4% and the temp is 42 deg.
Gpu usage is 1%, temp is 59 deg.
Are these temp all right? I read online people are getting lower temp overseas. I got 4 fans. 3 of them are stock fans which I am planning to check them too.
I've seen on youtube people are using i5 and 1050 or lower GPU, no lag! Below are the things I've done:
1. Re-installed Steam 2x
2. Re-installed Conqueror's Blade
3. Checked Integrity files
4. Checked all hardware is working well using the diagnostics test
5. Get the best graphic settings
6. Did not want to XMP my ram and my ram doesn't allow
7. Did MSI overclocking and it didn't work much
8. No Antivirus is working at the background
9. Startup programs were all disable
10. Open only Conqueror's Blade when playing. No other apps are opened.
11. You name it, I've tried all for the past 1 month but cannot resolve it.
12. Reformat the whole computer is my last resort.
I am not sure what to upgrade. If I am to upgrade gpu to 2070 and change the 2133 to 2400 ram, 2 sticks of 16gb, will it help?
Can someone or anyone who plays this game let me know more?
Many thanks :(
Fatfool
Could be a poorly optimised game.
The recommended requirements are only a Radeon RX 480
Swiftbladez
a quick google search showed some users reporting issue opening via Steam. You can try the direct client or something.
