Lancool K-series Users Group
acedarren92
the fan adapter sits vertically across a few dvdrom slots..and the fan is mounted in the adapter..
notice the screw holes in at the side of the fan adapter..they are for securing the fan adapter to the dvdrom cage..
i think and think still cannot imagine how u install sio. i look at the pic of k62 there is no hole for u to screw the adapter inplace leh? or is it u screw inplace at the dvd holes there?
repel89
wah..then the excalibur fan u can tahan?
mine is shelved liao..wahaha..
mebbe u can raise the legs and mount the bottom intake on the outside so that if wires wun be an obstruction?
Haha, okok la. Its only one fan not so bad. Only when music/movie is off then it becomes audible.
Lol, the front bezels can be taken out and this can be put in place. Haha, when the time comes when the rig is done then show u ba :D:D
vivi2005
1st round cable management
2nd round cable management
kaixax555
oc-ed to 2.8ghz, 44 degrees idle, stock cooler, non-aircon, turbo boost enabled...
ra[g]e
Oh ya, must ask u. With speedstep. How low does ur frequency and voltage goes?
I set manual voltage, when speedstep enables. The voltage doesnt change. Zzz Or u set to auto?
You need to use 'offset' voltage, not auto or manual :o
For that 'offset' voltage mode, base voltage is determined by multiplier/bclk, then you adjust... i.e. +0.15v for me (200x20) gives a linpack vcore of 1.35v... with this mode as it clocks down the vcore drops as well. Note that at 191x21 the base voltage I get is much higher...
Not at my comp now but iirc voltage drops to ~1.0Xv @ 1.8GHz at the lowest...
repel89
this one can count? I disable speedstep iirc
Y ur frequency so weird de? Haha.
Hmm, offset voltage. Think i couldnt find it in my bios. Maybe when u are home and free can take a screenshot of the bios for me?
Shall try looking for it again. Thanks! Cuz my voltage doesnt drop with the lowering frequency.
Thanks!
ra[g]e
Used google... this is how it looks like, see the offset voltage mode... except I don't use auto after that, I enter a fixed value.
This is the bios at manual mode:
