Lancool K-series Users Group
Kzhan00b
wow repel, nice hoots man. was @ sls just now. was looking for prolimatech just now but sadly couldn't locate.. maybe my eyes need some bearing check. just hoot a sflex f. was looking @ the kama bay plus for very long but decide not to get it. another leg torturing trip there.. maybe getting old liow.
Dont worry your eyes are okay :D
repel got from linkecomputer one..
repel89
Haha, bet u are younger then me!!! Megahalems? Prolinkdata and Scorpio didnt have it though. Why not the S Flex G for a bit more?
I would say its a nice deal for the Bay Plus. Note, i just tested it on the K62, if u put the Bay Plus at the front 5.25 bays u will not be able mount it with the screws. But i'm using it for behind the 5.25 bays so its still ok. So people planning to get it to mount at the front, it will not be possible. :)
And for those that plan to get the Bay Plus. It will not be possible to mount 120x120x25mm fans with the screws provided. Just a note.
bleed88
Kzhan00b> i see... tats y. spot a venomous x tho but my heart goes to pro..
repel89> younger? i wouldn't bet on it.. hahaha! the g, maybe when i get the hsf, then maybe then can consider. f so far quite quiet, but then again my ears might be not working well enuff..
i was looking @ the kama bay plus design, maybe i can diy something back @ my workplace. planning to put infront. i saw ur intended layout, i must say all these high end fan makers surely wished that every1's like u. hehehe.
Gelid fans are hard to find.. was really contemplating between that n scythe.
repel89
Haha, they have the black edition of the Venomous X!! Main reason I went with the Megahalems is that they allow the mounting of M12-P.
Haha, kind of like rig modding. Will see when my rig is up then can present to u all. Hope its what i expected :s13::s13:
Can consider the Noiseblocker fans also. :)
FastForwardToFriday
Haha, the penetrator wouldnt excel much as a heatsink fan. That choice goes to M12-P!!
Yup, quite hard to find it though. Managed to chance upon it while walking around SLS today.
Wa. what gfx u intend u use? Sounds like your casing is going to sound like a server room. :s13::s13: Haven decided which FC to get yet. Have to finish some spray painting and sleeving jobs. No time :(
errr buy i not going to buy m12-p to put in my 5850 leh, i using stock cooler;] (hope i can find 5850twin frozer)
for kama stay i just going to put infront of my gfx;] blow air into it!
lol! no las not home usage;] maybe going hoot some noiseblocker fan to put on kama stay. erm does kama include 2 3pin to molex connector?
u going spray pain ur case? awesome!! what colour?
bleed88
i see, my main reason is bcoz of its decepticon logo... lol. nolah, actually i've been reading a lot of reviews pass few days.. the big M still up there. tho some 'ppl' can say, "thats an old model... why not try this new 1?", still, i believe what i read. my main concern, i read sumwhere stating that lga 1156 chip best coupled with hsf with 6mm pipe X 4. while the M has six. any issue?
rig modding? hahaha! far from it, bend two plate i can get.. take some measurement and drill some holes.. then spray black. shd be good will try on a soft metal 1st.
noiseblocker... support germany!!! i work for german comp, maybe can give discount? hehehe!
repel89
Haha, MK-13 for u?? To replace the stock cooler u have!! Haha, must check if u have enough clearance to mount the Kama Stay.
Not sure about the Kama Stay since I haven used it before. My GFX is cool enough. Idles at 35 :)
Haha, not spray the case. Spray certain parts of it :s13::s13:
Haha, for heatsinks. Actually socket wise doesnt matter. In general, more heatpipes u got, the faster heat is dissipated. The reason y i went with the Megahalems also. Not sure if Linke still has the promotion. But its cheaper to get there :s8:
Haha, urs will confirm turn out nicer then mine!! Haha, Noiseblocker is pretty good. Have to try it out to prove it!
FastForwardToFriday
hahas nvm nvm! thanks anw will just use stock heat-sink;]
whats u mean by clearance to mount? kama stay is to put at pci slot rite? why need clearance? o.0
repel89
Cause u might have sound card or network card, Must check if there is enough place for the Stay and the fans when they are mounted!!
Haha, post a picture of ur rig here! See if can ask u hoot more stuff to improve =:p
FastForwardToFriday
aiyo! i haven get my rig yet but soon;] need save up 200more;] hahas..
no sound card or network card:D just one 5850
errrr stay can hold up to 140mm fans?
repel89
Wa, if need help can feel free to consult us :)
If one HD5850 should be no issue with it!!
Compatible Attachment:
(3x) 2.5“ HDD / SSD
Fan 80 ~ 140 mm
This is what they say the website. But for me, I would choose 120mm as the sweet spot for Kama Stay. Better and more options for fans
FastForwardToFriday
yeah sure no prob;]
o.0 why u choose 120mm sio? i will go for 140mm!! woot!! hahas
repel89
140mm more airflow;] btw where u get ur NB fans? erm will u connect ur 2 fans that will we mounted on stay to psu? do they provide 3pin to molex connectors?
Haha, for me i use a FC so its fine. Chamoxa has stocks when i went there today. Alot of fans there also. Almost tempted to buy more :eek::eek:
The 3pin to molex should come with the fans if u get them. If not u can purchase from Chamoxa or 6th floor also.
FastForwardToFriday
ohhh.. cool maybe will head down there see see one day...
sian i feel like getting h50 to cool i5-750+msi gd85(use OC genie) :D
good?
repel89
good?
Can try asking hg_wng, think he using almost the same config as you. Haha, u will get reasonable temps for a push-pull with that.
But if u ask me, H50 doesnt performs for the price it offers. $165. But if space is a constraint, then its a good option to consider.
FastForwardToFriday
ohhh.. sure will contact him soon..
o.0 really uh? performs not that good? than any recommendation? or i dun OC?
i thinking of this set up
i5-750+msi gd85
h50
any 1333mhz ram
samsung 1tb
dvd-rw
seasonic 620w
win7
lancool k62
how much like that uh?
i scared over my budget sio, 1.7k -.- or maybe can top up abit?
repel89
i5-750+msi gd85
h50
any 1333mhz ram
samsung 1tb
dvd-rw
seasonic 620w
win7
lancool k62
Intel i5-750 + MSI P55 GD85 $587 / Intel i5-750 + Gigabyte P55 UD6 $561
Corsair H50 $165 / Megahalems + 2 PL-2/S Flex G $160 IIRC
Kingston DDR3 2x2gb 1333Mhz $142 / TeamElite DDR3 1600Mhz $159
Samsung 1TB $93 / WD Black 640gb $94
DVD-RW $30
Seasonic M12 620W $132 / Andyson F500M $95
Windows 7 Home Premium $135
Lancool K62 $169
Think u are missing ur graphics card there. Those I bolded are good alternatives which I think are good IMO.
