Lancool K-series Users Group
Elijahonli
Nice, thread. K62 still under construction :D:D
And Kaixax555 ur cable management is :s22::s22:.
1) Route the 24pin from the top hole on the right side. Makes the bottom part looks less cramp.
2) U can actually cable tie the front panel USB and front headers together in front and make them enter through the same hole at the bottom
3) Dun understand y u inverted the HDD cage 90 degrees, Should have made the HDD cage face the other way, so that the back wires can be hidden
4) Should have used the right angled sata connector on the motherboard then instead of the port behind the DVD-RW
5) Personally i would put the HDD in the 2nd/3rd slot for the full effect of the front intake 140mm fan.
They have weird placement for the CPU fan connector though.
wheres repel89 kor kor k62 pickture?
Elijahonli
lol we quite funny leh, posting down here that we creating a Cm thread=.=
GegeV2
Here's the internal of a K62 I build a few months ago
Elijahonli
[IMGhttp://i50.tinypic.com/21chx6v.jpg[/IMG]
[IMGhttp://i47.tinypic.com/2ep13bl.jpg[/IMG]
Nice bro!
nicest picture quality, Clean cable management, good color combi too:)
StanII
kaixax555, ur cable management is horrific O_O and the hdd cage, i feel default placement is better, perhaps spend more time to redo the cables?
Bosco_wong
TS, where u bought yout k62?
Because i bought mine, but was not given the retention clip for the PSU, and the thumb screw for the mobo. :(
thegamer1907
they should be inside the white box with the rest of the accessories leh. go back the shop u buy from and demand for it lol
kaixax555
lol i do tmr ba...
i rotate my hdd cage cause sata power too short x.x
justln
K60 user here, didn't get K62 because I hate the LED lights. :D
K series got ALOT of holes/space for you to hide your cables, please do some cable management. :)
SPEED
my humble K58
U cannot even see my board because of the Huge D14 haha
SPEED
Noctua D14 mah haha
but its very compatible with many boards.
Not too mention the very solid mounting they have.
repel89
i can testify for Noctua's solid mounting!!
Front intake and back exhaust all Noctua. Top fans Noctua also?? :D:D
