Lancool K-series Users Group
FastForwardToFriday
Ok picture of my K62 after using cable ties... not much difference just that the behind part is neater. and of cos vx black!!!
hey nice cable mangement.. erm how come ur mobo looks dam small sia? the hfs nearly touch the ram liao..
FastForwardToFriday
ahhas cos taken from top view and e hsf is so big thats y mobo seems small, nah e 8 ram slot dere still can use!
cable management shi fu is repel !
hahas but its seriously looks dam small las hahas..
oyah btw when i go buy an oem win7 hp, how do i chk if i am installing a 64bit version?
KeYoKe
install finish liao go ur computer properties and check =X or check task manager if ur ram usable is 4gb (if u are using 4gb ram) if u see only 3.25 usable den means is 32bit
Cleaver
errr dun tink u can change leh... u buy 32 bit means 32 bit liao... i study windows server 2003 they say add /PAE to boot ini file... u can try... but i suggest u go google 1st... dangerous... later whole OS crash
but when u buy the os wouldnt it state outside how many bits? will be hooting a oem 1
KeYoKe
it will state... but i dunno FFTF bro got see anot... but it seems like his is 32bit wad... thats y he ask if can change 64 bit
edit: /PAE is to make ur OS determine 4gb and more ram on 32bit system... but do at ur own risk. suggest google b4 u do
Cleaver
thanks, /sign, think my total damage for a new rig gona hit 2k liao
FastForwardToFriday
so when i buy the win7software i need ask for 64bit de?
