Yeah, but sadly my mobo sata is positioned quite awkwardly. And another thing is squeeze so many cables behind the back wont the side panel on the other side be dented after awhile?
happened for my cm5
1st : sleeve sata cable to black, or use a marker color the whole sata cable black.
2nd: ur front panel connectors and ur usb front panel connector, use a cable tie and tie both together and make sure e usb front connector (black wire) is covering most of the front panel connector (advice from n00b, he taught me de)
3rd: 8 pin cpu can route from back of casing to the mobo... here is a guide on how to do. teron bro even bother to take pics and make it into a guide. this takes some time and patience and cut away that 8 pin cpu label dam ugly LOL!
http://forums.hardwarezone.com.sg/showthread.php?t=2839814
4th. PCI e cable can come out from the hole that ur atx 24 pin came out from...
5th: ur atx 24 pin connector can come out from the top hole instead of the bottom 1, will look nicer
6th: i dun use the cable snaps (the one at bottom holding ur psu cables) provided by the casing cos dam ugly, u can cable tie them together... since u like uv so much buy uv cable ties and tie together =)
7th: ur fans, all try connect to molex of psu by routing e fan cables to the back instead of connecting to mobo =)
