laptop 100% disk problem
ThePinkPanther
Hi guys. Recently my laptop become very lag and I found out that my disk is always 100% when I never open anything. Anyone know what can I do to solve this problem?
ThePinkPanther
ZrE0_Cha0s
since u are at the task manager, u can look at the one with highest usuage on the harddsik and see if u can stop the process or disable it totally, next whats the hdd u using? and is it running at full speed?
ThePinkPanther
My Highest usage is just 2.8 mb only
ThePinkPanther
I using 1tb hdd. How to know it is running at full speed?
ZrE0_Cha0s
Try this and printscr the info of your hdd.
Win+R -> key 'sysinfo32' -> den click on components and look for your hdd.
As for the application that is using your hdd to 100%, what is that app?
Intrinion
Senior Moderator
Senior Moderator
To add on, what are the 2 apps with 2.3mb/s and 2.8mb/s
combatuser
One of my friend had this problem. I helped her fixed this problem by changing the Virtual Memory to the windows recommended value. Default option is to let the system automatically manage it.
It may or may not help, but can't hurt to try if you have not done it :p
Steps below:
1) Open Windows Explorer
2) Right-click "This PC"
3) Click "Advanced System Setting" on the top left corner.
4) Click "Settings" for Performance
5) Go to "Advanced" tab.
6) Click "Change" button
7) Uncheck "Automatically ......."
8) Click the circle dot beside "Custom Size".
9) For both "Initial Size" and "Maximum Size", put the recommended value shown at the bottom part.
9) Press "OK" button and restart PC.
ThePinkPanther
Steps below:
Thanks but did not work :(
