Laptop Issue
harky
U mean the laptop? why i not using anymore?
the last i use, everything was still function but the graphic card is spoilt.
It had blue line.... , it half die... now full die lor. :s22:
So keep aside and i had been finding the graphic card but it quite hard to find because it belong to MXM HE slot which not longer released. Want to get 2nd hand one rather than new one due to the price. For the price can actually get a low-end laptop.
Try ram first. Personally experience no display issues due to ram countless times. If there are two sticks, remove both and insert one.
Any hdd activity indicator or power indicator on the laptop? That should work as well.
One more thing what was the issue prior to you not using it anymore?
harky
check my laptop...
can charge battery :(
hdd no issue. can read from external hdd enclosure
harky
no.
because when i turn on... the laptop
power on; not booting; hdd off, fan off
doubt i will able to see anything from monitor.
*no sure the 2nd hand graphic card i got it isit faulty or motherboard die just like tht?
have u tried to check if display issues by using external monitor?
Intrinion
Senior Moderator
Senior Moderator
2 possibilities :zotto:
Try swapping ram to see if it works?
2nd hand graphics card could be an issue as well :(
no.
harky
i got take out but nothing moving :(
maybe i go try my luck to get other low-end model card but use on same system one. after i get this refunded LOL
give a last try :s13:
Keith Chan
I have a Asus Zenbook UX310, dedicated graphics card nivida 940MX, from the picture u can see the words in the program is not as clear as those on the desktop and task bar, any idea on how to make it clear? It happened on some other programs too.
ZrE0_Cha0s
google for cleartype text. and windows will adjust it for you.
Intrinion
Senior Moderator
Senior Moderator
To be honest, it looks alright to me.
You can try this though
Start >> Performance options >> Adjust Windows for Best Appearance.
Or alternatively
Look under the options and ensure
"Smooth edges of screen fonts" is check.
On another note, do try to post unrelated queries in a new thread. Allows for easier check back / faster responses.
Have a great friday
