Laptops with removable battery
denpahenkan
Hi,
Need some advice on some laptop modals that have removable battery. (Preferably gaming modals but not looking for high end)
Reason being is that I do not want to overcharge the battery and affect the battery life when I am plugged in. I do not want a laptop with integrated battery that has a program that prevents the battery from charging to a certain threshold as it don't really help much - I used to have a laptop issued by my company that has this program that automatically prevents the battery from charging past a certain %, but since my work laptop is always plugged in like 99% of the time, the battery life eventually still dropped to like 5 mins after 2-3 years of usage. Would prefer to look for models that has win10 pre-installed instead of win11 as well as I still don't trust newly released OS.(I lost my entire drive of data back then when win10 was just released and some stupid update caused my labtop which I bought back then to go into a BSOD loop.)
This model has a removable battery but it seems to be out of stock locally.
Gigabyte G5 KC
congster2
Not sure if this exists today. It's all the same. Laptop batteries tend to give way after 2-3 years of use. When it's done just replace it. Also if you need additional power, check if the laptop supports thunderbolt powerbank charging and get a suitable powerbank.
