Laser jet printer recommendation
feigningfancy
Any recommendation for a laser jet printer? Im currently studying and require a lot of printing (double sided, ink efficiency and can print colour also). No budget set at the moment but will appreciate a cost worthy printer. Thanks!
magix
the last time i remember laser colour is not cheap the toner.
dreamer_toons
I’m using a Fuji Xerox colour printer 225FW for 2 - 3 years. It is a copier, scanner, fax and has duplex printing. Duplex printing is not auto, need to reinsert the printed page 1 back into the tray for page 2 printing.
It was about $500+ then.
Toner is about $90+ each at Challenger but manage to source a deal at Qoo10 selling at $60+ during the last round.
Tan Gee Ming
$500 so much.
nwh_sg
If you dont need colours and copier features, it will be cheaper too.
I found it more 'economical' to buy separate scanner (stand-alone) plus a printer instead of those multi-function printers. In that case it is cheaper when you want to change the printer. Scanner can last quite long.
hellspawn_one
the main cost driver is the colour printing and duplex printing. Cheapest is B&W laser printer, add a bit more can get scanner cum B&W laser printer.
