LED light driver
Beh-Hawk
hi all, anyone knows where to buy LED light driver? do they even sell it separately? mine went kaput :(
blade
Standalone driver can be buy from Taobao, just buy the correct wattage. I changed my existing driver to remote control type. Have not check locally, but most likely it can be bought at Balestier Road light shop or Sim Lim Square.
cscs3
I have some spare. PM me if needed. I do need your old driver box so that I can transfer the original cable to new circuit. Same rating as yours, support up to 25W LED light.
cscs3
Buying from Taobao better becareful. Not only price varies. Quality too. So watch carefully the following points.
1. Isolated or non isolated. Non isolated means your electrical live circuit is pass thru from input to LED board. So do not touch LED board when it is power on.
2. Fused or not fused. This is additional protection to your LED light or incase anything wrong. It should not tripped your house circuit breaker.
Other then this. Check those components used. Some driver use very small transformer and is very hot when LED light is on.
Bad quality
https://www.dropbox.com/s/wewcpy07cyezqie/20170115_143936.jpg?dl=0
Not bad
https://www.dropbox.com/s/apyi97rro7vgzlg/20170115_144211.jpg?dl=0
With fuse protection
https://www.dropbox.com/s/4l9uynkf888s3b4/20170115_144324.jpg?dl=0
Beh-Hawk
Bad quality
Not bad
thank u bro!!!
lightchaser
hi, sorry I am new . can we just buy any driver as long as the wattage is the same ? how abt other parameters ? thks !
blade
If you buy from SG physical shop, it should be quite safe to buy any driver as long as wattage is the same. If buy from online shop, need to check the input voltage is the same as singapore 220/240V.
cscs3
Normally driver unit covers a range of wattage. Eg. 18w to 24w. As long as your LED light fall in the range plus the current rating Eg 300ma. Then you are fine.
LED light use constant current circuit. Most common used in home is 280-300mA type.
Connector type is also important. You can get some ideal from here. Best is don't throw away the old one so you can transfer the wire/connector over.
【LED驱动电源变压器1/3/7/8/12/18/24/36W恒流隔离IC筒射灯宽电压】http://m.jevwv.top/h.3jG1HEa?sm=db5d19 点击链接,再选择浏览器咑閞;或復·制这段描述¥Vl89b76gZG4¥后到👉淘♂寳♀👈
【包邮内置led非隔离驱动8-24W电源24-40W 50w恒流带安规压敏变压器】http://m.jevwv.top/h.3jG4sZb?sm=6dd5d5 点击链接,再选择浏览器咑閞;或復·制这段描述¥sBB7b76RNA3¥后到👉淘♂寳♀👈
