Let's Accessorize Your S7 / S7 Edge
Zephon
mine still running naked lei, guys really no reliable tempered glass protector? Feel unsafe for the 39.9 one from Qoo10.
Zan78
Does the Healing Shield for the S7 Edge feel rubbery or smooth like tempered glass?
royfrosty
Seriously guys. Go ahead and try p2o. The protector for s7e is good. Thin and yet edge to edge. $19.90. And its not those rubbery type. Yet with a little oleophobic coat on it.
Also note that only selected case can be used. If the flim just comes out just keep pushing it back apply a little pressure. After a day or night, it will stay there.
KYLee
Just applied healing shield at mobile hardware. Got abit those rainbowish effect and side one part won't stick.. Pretty bad.. But the rinke case they recommend is pretty good! Living it
cspotato
I am using a slim clear TPU case for my s7e without any sp. Enjoying the smoothness of the screen and the curves of the phone. Will be looking out for some sp.
KYLee
I removed the healing shield just hours after putting. Really ulgy rainbow fuzziness that defeats the purpose of the beautiful screen. And it's slowly starting to peel off too even only after one day. I'm probably going to use this naked with my rinke case. Nonetheless great service from mobile hardware
royfrosty
Lol seems like p2o offers better quality sp then hahaha.
No rainbow effect. When reach hime will take a pic show you all.
Bardiel
fwah wasted sia.
i was thinking to go down put healing shield, after i see most of the review i nv go.
heard it's silicone base, rubbery surface.
think naked edge if really no choice
ecneret_eel
quite tempted by the S7 honestly, but seems like everyone is only rocking the edge version here, would you guys discourage me from S7?
CatLuVer
Went to mobile hardware at burlington, one shop at bugis village and 2 push cart stalls at bugis junction. All don have S7 edge screen protector :o
KYLee
fwah wasted sia.
Yes it's silicon. The side is popping out after a while le. And I got the last piece. Until a proven reliable one comes out, I will be using it front naked.
tjkjean
My healing sheild from nex still working fine. Probably it depends on the person applying. No rainbow effect for me as well.
PiPiChew
Ok for Spigen case this is how it is.
Thin Fit series is the thinnest case out there that provide minimal protection*, usually with exposed sides or buttons. This is good for people whom do not want bulky case, and it is made of hard plastic with matte rubbery surface.
Liquid Crystal case is 2nd in line for thinnest case but not hard plastic, it is made of soft TPU rubber. Which is flexible and bendable. It covers all the area of the phone, but it is of bare minimum or close to 0 protection when it drops. Cause it is so soft, usually the impact from a drop usually will still leave a dent on the phone.
Rugged armor is the 3rd in line for thickness. Unlike like Liquid Crystal, it is matte black and made of much thicker TPU rubber. And has their air cushion at the 4 corners of the case. This offers, good protection all round, yet not that thick and bulky.
Ultra Hybrid is a different approach than the above classic 3 case. Ultra Hybrid balance the need of aesthetics yet maintain good protection without sacrificing by adding more bulk. Ultra hybrid has a transparent hard plastic back and the sides are all thick TPU rubber. It has air cushion at all corners to absorb the impact.
Neo Hybrid is the same as Ultra Hybrid, but instead of TPU rubber for the sides, it uses metal instead. This is to give the "more premium" feel of the metal sides. Also it is made of 2 different pieces, metal rims, and full TPU rubber back cover and sides. But many including my friends have complained about it, as it felt slippery from hand, and not really good to use.
Neo Hybrid Crystal no difference from Neo Hybrid, but instead of plastic and metal in 2 different piece like Neo Hybrid has to offer, Neo Hybrid Crystal offers plastic back, and TPU rubber sides.
Next in line is the complete armor series with no compromise in protection. But however it is very bulky imho. Starting from the slimmest armor series.
Sim Armor is the thinnest 2 piece protection, the body 1st layer is covered with TPU rubber, while the add on piece is a hard plastic cover for the back.
The second thickest will be Slim armor CS, this is thicker because instead of a kickstand like how the Slim Armor has, the Slim armor CS is for Card slots.
And last of all the mother of all armor case, the Tough Armor. This case is not much thicker than the Slim Armor, its only the side rims are thicker than the rest. But this comes in a whole single piece rather than 2 pieces. But some claimed that it is so tough that some said, they drop their phone countless of time, and this case never failed them.
*Typo
Wahh sibeh power decription. Really really Upz bro :D
Sent from 10 Buangkok View, Buangkok Green Medical Park using GAGT
