Let's Accessorize Your S7 / S7 Edge
lunzi88
Huh? Bo leh? The standard things in the box is the hp, wired charger, earphones & the connector.
.... what he meant is that the adaptive charger that came in the box IS a fast charger.
I recontract myself from M1 as well. :o
Qoojay
The wired charger in the box is the fast charger liao. Under 2h charge finish from less than 10% to full.
Sent from 10 Buangkok View, Buangkok Green Medical Park using GAGT
that charger in that box IS the quick charge charger. they call it adaptive fast charge
OIC. My apolgies. Dunno the actual term:D
Im looking to buy a gen2 samsung fast charger.
The other thing i want to buy is MicroSD card. What's the diff bet HC & XC? Is class 4 cards good enough for S7?
PiPiChew
HC means Hugh capacity and XC means extended capacity. No diff in performance, merely a name to indicate GB size.
Class 10 faster than Class 4 and honestly I recommend Class 10 la. Phone so fast, get a fast card also better mah. Now is like less than 50c/GB for Class 10.
Qoojay
Tks for the clarification.
I understand class 10 is better than class 4 but if class 4 is good enough then not need waste $ buying class 10. Just like Octane95 petrol is good enough for most cars so no point paying extra for Octane98 or Vpower.:)
tkl23786
You drive Ferrari also use Octane95???
Same logic...
:s13::D;)
Qoojay
That's why i asked if class 4 is good enough, if good enough then no need to overkill. Of course higher better, all i wanted to know is the exceptable standard, that's all.
PiPiChew
I see. I can't properly advise you then since I have no experience using Class 4 and therefore can't give you accurate examples. From what I read online, the general consensus is class 10 for taking photos and videos etc. The higher tier one for 4k video taking. Not much has been mentioned about class 4.
Perdedor
Any buddies with good tempered SP that covers the whole S7 (non-edge) screen to share?
TrueB1ue
Class 4 = 4MB/s
Class 6 = 6MB/s
Class 10 = 10MB/s
UHS1 = 10MB/s
UHS3 = 30MB/s
Samsung EVO = 48MB/s
Samsung EVO+ = 80MB/s
Samsung EVO pro = 90MB/s
Samsung EVO pro+ =95MB/s
maisatomai
Been using s6 and now buying s7
Did some research on the memory card. If you want to use 4k it seems that you need to get a good memory card with around 90mb write speed. As memory card has a lot of fake it is important to be careful with it.
4k video take a lot of space and it best to get a 128gb. There are two brands that people normally buy, Samsung and sandisk. And in Amazon review samsung seems better. As only the Samsung pro provide 80-90mb write speed it best to get that. But problem is Amazon don't sell that.
Another way is to just get a cheap class 4 128gb and do all recording with the internal memory. And everytime after recording transfer it to the class 4 memory.
I read that if you use a memory that is not fast enough s7 will skip frame
Perdedor
If it helps, I bought a SanDisk extreme Pro microsd (95/90 MBps, read/write). Costs around $70 for a 64GB microsd.
Look for the 'Extreme Pro', the 'Extreme' variation has a slower write speed at abt 40MBps:
https://www.sandisk.sg/home/memory-cards
kimsix
Bought official Samsung black fast wireless pack and 64gb u3 microsd from Amazon and other things for free shipping.
I checked with Samsung shops, their wireless charger for s7 not out. Saw online they are plenty of 1-1 replica of this fast wireless charger, so I feel safer buying from Amazon and it comes with charging adapter while I see local sales only the base.
Fake ones are lighter and missing the internal fan to keep it cool but they look exactly an identical copy
malaikai2005
Huh not out..you mean the round one?
I exhange my voucher for the white one leh
I want black but out of stock
Expensive at $98
gapboy
ya i got the gen 2 wireless dock too, doesn't seems to charge well with cases like spigen ultra hybrid case ... too thick tpu i guess ..
kimsix
Expensive at $98
That is what the Samsung store told me. I checked around and saw many shops selling it from $60-88, wanted to buy the cheapest one but I checked online, it is really hard to tell apart the replica unless u weigh it or dismantle it to see if there is a fan inside. Does yours have a fan spin up when charging long time?
