LG G Pro 2
LongGe2009
The slim design and bezel looks so much better than note 3, last time I really 瞎了眼 buy note 3.
progene
LG market G3 more than LG G Pro 2. So many not aware such phone exist.
And yes. Many only know Android is Samsung.
blue24
Estimate ard 90 min
Hi Friend, Thanks for your reply.
My stock Pro 2 charger (1.8A) is charging quite slow, charging speed is 2 hour increase 10% only.
any bro here know what had went wrong? cable spoilt, stock charge spoilt, bug or?
I am thinking of using my 2A samsung charger instead. Would it cause any problem to the phone or battery?
Thanks in advance.
tkte_85
Thanks in advance.
using stock cable?
kelvinti
Big welcome to those late comers! :)
Pro 2 is simply the best huge screen phone.
zzcalvin123
Thanks in advance.
i dont check the timing. normally i will leave the phone alone than 2hrs later come back to check if is charged use until 4-5%
Mugen
Thanks in advance.
When u plugin for charging, does it show "Slow Charging" on the status bar? if yes, then it could be the cable or the charging port got problem.
LongGe2009
Hahaha.. Luckily u managed to 回头是岸。。 :s13:
Got the black greyish colour one from a shop in town, with rubber case and tempered glass screen protection around $620. Awed by the massive screen size and clarity, 爽呆了!
The 3gb ram really helps alot in speeding things up.
kelvinti
Indeed!
Even the Note 4 is still not as smooth and as speedy as the Pro 2!
benny888
Indeed!
I find my other Note4 is definitely much smoother n faster than my LG G Pro2. Anyway this phone is excellent by itself. Had been using Note4 about 4 weeks vs 6 months for this LG phone. I just got Mate7 last week n this is a strong contender w LG too. Its battery life is amazingly great at average 10 hours SOT vs 7 on the LG. Everything else equally good if not better than this LG phone. Will pass down this LG to my family member
zzcalvin123
Note 4 with the latest s805 should be faster than the g pro 2. so touchwiz isn't slowing the note 4 down?
benny888
Mine is Exynos version. Based on all web reviews this time Exynos performance much better than SD version.
Absolutely no lag on Note4 n is even very very much better than my other ip6+. Samsung had done a very good job this time on touch wiz. I had used all the Note series n only this time I am proud of the Note4. However is smaller display is a bit dissapointment n yes I just hate its Amoled as colors oversaturated n too bright. Still prefer LCD type displays while many reviewers do praise it highly
zzcalvin123
The exynos on the note 4 is the latest 64 bit one? How the battery life?
LongGe2009
To me the 5.9 display is the crucial key, was waiting for a follow up to Samsung 's mega 6.3 but alas the successor seems so weak, then looking at Sony T2 ultra but the specs is pure sucky.
Always wanted something close to 6".display with top range cpu and specs.
这还是最棒的!really 赞!!!
zzcalvin123
这还是最棒的!really 赞!!!
Maybe next year Sony doing a z4 ultra (rumor)
Genome123
This is really a good overall phablet, though the resolution is not as high res aka G3 but the screen size and low lag really pushes this piece through borders.
Coupled with a slim body and thin bezel makes handling so much better, glad I sold my g-pro for the newer g-pro 2.
My old fav phablet the galaxy note 3 can finally lay to rest as well..amen...
lumpyme
any idea where can i get a replacement battery for this phone at the cheapest price?
checked qoo10 but no results found
Nakedtoes
这还是最棒的!really 赞!!!
Think the mate 7 with 6 inch screen n yet thinner n smaller then G pro 2 looks interesting
