kelvinti
- Jan 5, 2009
Oops..Looks like not ok. Give up.
May be there is a rough app that caused a conflict.
I've not tried v20a but had issue with notification light with v20b. So far,
v20d from taiwan is most stable. =)
sorry to ask...
currently having v20c(Taiwan Version), how do I update to v20d(Taiwan Version)??? when I check for software updates, got prompted that v20c is already the latest version... btw, my set is not rooted.
Thanks in advance...
No apologies required, forum is to help one another.
The update is not OTA, I flashed it manually from downloading the official firmware from the website below:
http://lg-phone-firmware.com/index.php?id_mod=62
Go read and search within this forum on how to go about doing it.
Is it worth it? My opinion, absolutely. Couple of hours of effort for this super phone to be back in my list of best in phone yet, still, as of now.
Thanks man... got v20d up and running by using LG flash tool 2014... hope this version improves the battery life...=)
Learn and apply this stuffs at your own risk.haha.
Good post. Thanks.I agree with you on this. Before proceeding to flash, bery scared that the phone will be bricked... lucky turn out well..
falcom2002 - try the following steps at your own risk!!!!! if can't work, your phone will be bricked and need to go service center.....
My phone is not rooted so I guess the normal procedure works.
If your phone is rooted, PLS DONT TRY THE METHOD AS STATED BELOW~!!
1. Download LG USB Driver for LG G Pro 2 from http://androidxda.com/download-lg-usb-drivers and install in windows.
2. Download LG Flash tool 2014 from
http://forum.xda-developers.com/showthread.php?t=2797190 and extract it.
3. Download LG G pro 2 v20d Taiwan firmware from
Note: choose (Taiwan region - See - 26 TWN/TAIWAN V20d LGD838 1.07 GiB)
The firmware is in KDZ format - put inside the extracted LG Flash tool 2014 folder.
Connect your phone to your pc usb port - it should now show installing LG usb drivers.. let it install successfully...
Start LG Flash Tool 2014 and follow the procedures from
Good Luck~!~!~!
Good post. Thanks.
Do you need to put phone in download mode?
I tried but failed: off phone, hold vol up and plug in usb.
Did I do it correctly?
Edit: Got it. But did not flash.
Looks like everything is going great for you.Yes, you need to put phone in download mode when connected to pc and running LG Flash Tool 2014 as stated in 3. Tutorial:
encountered 4G/LTE not working after flashing..managed to get it back by following - http://forum.xda-developers.com/lg-g-pro-2/help/d838-getting-4g-lte-t3025868/page2:
1. Access hidden menu by dialing 3845#*838# on dialpad
2. Select "WCDMA-Only"
3. Select "Modem Settings"
4. Select "Network Mode"
5. Select "Automatic"
4G/LTE's working once again... =)
Frankly speaking. I have never experienced that WhatsApp LED blinking issue with my Lollipop in the past week.
Setting the Vibration to long instead of default or short vibration in Whatsapp may just cure the issue.
Sounds strange and rediculious...No harm giving it a try..It is just a few taps away..![]()
May sound silly though but i will give it a try. Led at times still cannot behave.![]()
No worries. You can save your face. Ha ha ..Haha!
Thank you for giving me face! If it doesn't work, you can slap my face later!![]()
