LG G Pro 2
kelvinti
Its just nice :)
I just emailed them about it. =:p
You still have what interesting app(s) bro ?
Did you see the green battery % on my bar top?
That app can notify you when phone is in low or full charge with different colors and can use custom tones as well according to you own setting.
With that, you can deactivate the stock white battery % which only in white and too small. ;)
kelvinti
Quick qn...lg g2 or g pro 2?
What is the screen size of your current phone?
For future proof and the real enjoyment of social and entertainment apps as well as texting with bigger fonts for easy readability and preserve good eyes sight, G Pro 2 is the wise choice.
Frankly, G2 is quite small the screen for the above mentioned purposes.
In texting, once the keyboard pops up, 3/4of your screen is gone and that makes it very difficult to read previous texts or messages. :(
Whearas with big screen likes Pro 2, there is so much screen to spare. You will love it. :)
shorty07
If you don't mind big screen...
G Pro 2! :s12:
G2 no removable battery and card slot unless you buy korean set...
Plus the 4.4.2 on G2 still buggy ;)
will it b too big for pants pocket? cant try at shop since the set is tied down. n wat abt specs? any significant difference?
Unknownx
It can fit in my quite tight bermuda with thick case somemore lol
Same processor and gpu but G Pro 2 has slightly better camera and more RAM
shorty07
im currently using s3. size wise, i compared n see that g2 almost same size. but can also see that the screen is bigger. even though upgrading to pro2 means really upgrading the screen size, afraid that will b too big. esp if cant fit in pants pocket.
shorty07
hmm...means its faster, right? wasnt even thinking abt the pro2...till i realised the price not much difference. but the g2 is still considered the flagship fm LG, i read somewhere. sorry if it sounds stupid...but still new to lg. hoping to jump after using S2 n s3.
kelvinti
If you wear tight jean with swallow pant pocket frequently, the lenght of G Pro 2 may make you feel sligjly uncomfortable a bit as it is longer when you sit down. The head may pops up from your pocket. However, most of the time, we take out our phone to use when sitting down. So, not a major issue at all. No worries. !)
Anyway, most pants be it tight or loose, have deeper pocket now.
Unknownx
Not that sure but I think it would be about the same performance
You should try both phone at telcos first and feel it, which one more shiok :D
kelvinti
Also,from S3 to big Pro 2, you may feel crumsy at first. But, it is a matter of time that you get use to the size and don't feel crumsy anymore.
We all also upgraded from 4.7" or 5.0" or even from 4" of iPhone ba
No problem at all now. ;)
Go get the Pro 2 like all of us here. You will not regret it. Watching YouTube has never been any better and shiok with a 5.9" big screen. :)
Just go compare watching YouTube and video with 5" phones and 5.9" of Pro 2. You will know what I mean. ;)
Unknownx
G2 is still very laggy here and there. :(
Something to add on, if you google "LG G2 problem" it will shows quite a number of result...
Meanwhile "LG G Pro 2 problem" is none lol
Btw I'm coming from Z1 Compact (4.3"), it only takes awhile to get used to the 5.9" screen :D
shorty07
no tight jeans or pants for me. fat butt cant fit into all those slim fit pants:o
i would love to hv bigger screen...but still unsure if i NEED it.
kelvinti
To add it up, Pro 2 is so so so thin and sleek with rounded edges and it makes it so easy and comfortable to hold and operate with both hands or even with one hand unlike squarish of Note 3 and Z2 or other big screen squarish designed models.
Unknownx
Just hands on both phones first at telcos, I also did that :D
After I tried the G Pro 2, never bother about the G2 already haha
To add it up, Pro 2 is so so so thin and sleek with rounded edges and it makes it so easy and comfortable to hold and operate with bith hands or even witg one hand unlike squarish of Note 3 and Z2 or other big screen squarish designed models.
We two like keep shooting poisons LOL
shorty07
oh...G2 laggy?...didnt know abt that. did read up on g2 thread earlier...but i also lagged behind after missed so many pages. so didnt get to read on the probs.
wait.....r u guys recommending me the pro2 cos u r using it?...biased opinion?,... hehehe. but glad to hear no probs for it so far.
