LG G Pro 2
kelvinti
Persie
Not bad! Nillkin case is well known for its well crafted case with solid quality.
It is not a thin case and it is considered a heavy case compare to other snap-on case.
I used it on my precious G Pro for a while. I changed to IMAK Crystal Clear case. It's thin, light and durable.
I almost bought imak case for G Pro 2...is the edge of this imak case very sharp? Wont scratch the phone right if i keep taking in and out of casing?
kelvinti
Don't worry. I know that the IMAK case looks thin and looks like it cannot take heavy impact but the truth is that IMAK case is also very well crafted with very well polished edges. It will not scratches the side of the phone by taking it off and on.
It can withstand heavy impact from dropping too. A lot of people don't feel safe as the crystal clear case looks thin and weak but the fact is that the material used on the clear case is super durable.
The case is also quite scrtache resistant.
Trust me. I have used this IMAK clear case on my HTC One, G Pro, Note 3 and now I still will use it for my G Pro 2 without any worry.
kelvinti
Anyway, the stock browser of LG G Pro 2 is one of the fastest browser I have ever used if not the fastest on any mobile phones. ;)
kelvinti
Anyway, I have just canceled my order for the Metallic Blue case from Germany.
I still prefer a clear case or semi clear case lor. ;)
kelvinti
Another case to be considered although there is no case for G Pro 2 yet. I also use this matte semi transparent white case on my white Note 3 is it is pretty good!
I'm waiting for the Pro 2 model to pop up from this awesome eBay seller.
dreamvivastore | eBay
Persie
Ok...thanks for the review...buying it in a minute!
kelvinti
Folks,
1. What is the dial code for test menu?
2. How to get into the "DOS" bootup menu on G Pro 2? I wanna perform a clear cache partition...=:p
noobzpro
Dam sian just got my case......so started peeling off all the protector of my phone and noticed a chipped in the glass at rhe bottom right....how ah? Gg right?
noobzpro
kelvinti
Where did you buy it from?
Call the shop if can exchange another one.
I guess that out of good customer service and to gain customer loyalty and trust, the shop should do a 1 to 1 exchange without question asked.
After all, it is only the 2nd day. ;
