Lian Li PC-O11 Dynamic Chassis
gld998
Yeah.. i want one too, looks good.. but i prefer the air version though.. me wanna avoid water cooling after a few disasters. :(
Sent from Old Man Pressing For Retirement using GAGT
singupingu
Heart itch for this chassis and upgrade gpu to do custom loop. But it's so painful to the wallet I wanna cry :(
Sent from OnePlus ONEPLUS A3003 using GAGT
shadow84
Compared to the $500 that i paid for the O11 1 year ago, this new ver is quite the improvement. If i didnt change from my 750D last time, i will have changed to this O11 dynamic instantly.
And the price is not bad as well.
shadow84
Buying this case means die die must do watercooling???
KeYoKe
i plan to hoot this case and put in a corsair h150i only for my another rig :s13:
joeltng
just fyi
Cedesria
Those who bought the original PC011 sure sianz. Only consolation is that their original pc011 is full alu....
royfrosty
Any way, the original O11 is mainly alu. BUT however it is made of steel inside.
If you all noticed the new pc37 o11 o12 series all are made half steel half alu.
Hence the price is slightly lower than most of their other full alu towers. However it is still on a high side such as paying 4xx to 6xx for it.
The original o11 have all alu for both the side and front panel. The mobo tray is alu.
The things that are steel was the case structure, pcie brackets and the hdd cage.
This new o11 dynamic is all steel material. A redesign on the inside. Accepting a proper 2x 360mm rads with push pull and also bottom rads. Making it the smallest case to fit in a lot of rads and yet without compromising cable management space at the 2nd chamber.
royfrosty
Lol not full alu leh. I was bored, so i did a magnet test lol.
The main structure is all steel. Only mainboard tray, side and front panel alu. Haha.
