Liquid cooling AIO 120
JoePilot
Yay or nay?
Is it overkill for i5 overclocking? Non-aircon conditions
Encrypted11
Umm, nothing wrong with 240 30mm thick or maybe 120 50mm AIO in its raw performance. It is the crap stock AIO fans that are holding heat dissipation back though 120 30mm rads are a no go.
Swapping to gentle typhoons or even lower tier noctuas will yield a huge unanticipated improvement.
But I'd say go for delidding (voids warranty) first and go for a decent mid tower or full tower air sink because of performance per dollar and lower noise.
joshuaho
Which chip are u using? Varies across the different generations. Also depends on how much u intend to OC, if u want to hit the absolute limit (before LN2), it's advisable to get a 240 40mm. However, if u just want to OC a 0.2 or so, I recon a 120 40mm would be enough. Aside from the radiator, the fan used also important as it is the main source of heat dissipation (maybe can get a 2150 or something RPM and set your own fan curve)
JoePilot
Latest, or upcoming generation of i5. Thinking of Arctic Liquid freezer 120.
Yes, definitely will try delidding first.
