Logitech G613 Double Typing (Key chatter) Issue
Gambler.
Bought my G613 from Newegg during 2018 BF sale.
Now having double typing issue which is quite annoyingg
From Newegg's product site, it says there's 2 years warranty so means it's still under warranty.
Anyway I can get this fixed? :(
Lil_d3viLz
Bought my G613 from Newegg during BF sale.
It is covered under warranty for key chattering. Go RMA it. Yes, I know. Especially typing documents or gaming. Double-press = unwanted letters or actions.
Gambler.
Thanks, that means I've to contact Logitech US directly?
Godeau
Wait till you try typing passwords with a chattering keyboard, lol
Koenig168
I'm WFH now so it's blboody annoying.
most common buttons are T, G, FF, E
You can turn on filtering. Either the bounce or repeated keystroke or both options should help until you get a new KB.
Gambler.
dunno how the RMA process works with Logitech since I didn't buy this locally.
I just dropped them an email
t258jgn
I also having the same problem
Almost threw the keyboard out of window :D
localITguy
Suspended
I love logitech products, but their customer service /rma is handled by distros in SG (which has terriable service) ( You should know which distro.)
not to mention Logitech's QC is also crap
if i buy a logitech product, i am prepared to fix it myself or just throw away.
your product buy locally or via newegg? if not buy locally. u can just throw away ( as the both distros over here won't handle non local products)
If your product is not purchased locally, just throw away or fix it yourself.
Don't visit the distros, they most likely won't entertain you
if it's purchased at a local store.
Logitech will re-direct you to the two distros for logitech product ( standard SOP)
Please email both of the distros your S/N of your product and product name ask if it's under them.
Do not visit any of the distros. until you get a comfirmation that they will handle RMA .
Some distros like to play taichi they will push and say it's not under them..
So please check before you head down.
so you don't waste your time
Logitech will not handle replacement service directly to you ( You not in angmo country)
Gambler.
thanks! i bought on newegg so i contacted logitech directly via email.
let's see what they say then.
hellspawn_one
I have the same issue but luckily it's the space bar only. But irritating to have 2 spaces here and there when typing work related stuff.
Sent from Samsung SM-G970F using GAGT
dgenex
I also have the same issue, bought from Newegg at same time as well.
Can try removing the affected keycaps and cleaning the dust from the keyboard, then reattach. It seems to have fixed the issue for now for me.
Sent from Xiaomi M2007J20CG using GAGT
hg2
Their product quality has dropped and they knew. So they cut short many warranty to 1yr only, e.g MX series...
If you brought online, contact logitech via email they will issue u a local RMA code. Most likely a 1-to-1 exchange...:D
hellspawn_one
How do you remove the keys?
Godeau
I'm not sure how easily serviceable these logitech keyboards are, but if warranty is already over, have the right tools and feeling adventurous, you could try sourcing some romer-g keys and replacing the affected keys yourself. I did that for all my cherry switch keyboards.
Gambler.
I emailed them liao, no reply so ffar. :s8:
dgenex
I followed some youtube instructional videos to remove, using ruler.
https://m.youtube.com/watch?v=cr8HpOyqvlc
Since this keyboard dont come with a keycap remover its abit harder. Tried using tecware keycap remover but doesnt fit :(
Spacebar quite hard to remove..
I noticed after the first time i remove after that the keys are much easier to remove
yosemi
my kb is covered by local disti and I got it RMAed.
more than 6 key have double typing problem.
double typing issue as well. its very irritating when typing password . keep type wrongly end up with account locked.
Lil_d3viLz
Try using alcohol spray into the keyboard after removing the keys. Wait overnight to dry. 99%alcohol. 70%alcohol might take 2 days to dry.
I solved my key chattering issue this way.
Stanley W
Oooooo I thought I'd because it was smashed by my baby... So now everyone also having this issue lol
Sent from HUAWEI NOH-NX9 using GAGT
